Post by NP317 »
I will check tomorrow what size the top vent valve is. Probably 1/4" i.d. passage.
It was chosen for functionality and strength, not through hours of mathematical calculation... :lol:
djjh87
Post by djjh87 »
The rods turned out awesome. That task is coming for me soon also. Jim
No problems just solutions.
Odyknuck
Post by Odyknuck »
Thanks djjh87. You plan on making them manually or CNC?
Odyknuck
Post by Odyknuck »
NP317 wrote: Sun Nov 27, 2022 1:20 am I will check tomorrow what size the top vent valve is. Probably 1/4" i.d. passage.
Ok let me know. Looking back at your construction of the rods, I see you made sure all your links were correct before completing the machining,
Did you have any issues with warpage and or movement of the hole centers?
Post by NP317 »
I finished the rod bushing holes first. No use doing more if those are not correct.
I used 304(?) stainless steel for the rods. It was very stable and machined easily at slower speeds. Not much heat generated, and no detectable warpage.
JBodenmann
Post by JBodenmann »
Hello My Friends
Very nice rods! CNC is definitely the way to go if you have the skills, and access to machines.
Jack
Odyknuck
Post by Odyknuck »
Thanks Jack, I'm in total agreement on CNC.
Odyknuck
Post by Odyknuck »
NP317 wrote: Sun Nov 27, 2022 11:40 am I finished the rod bushing holes first. No use doing more if those are not correct.
Thats good and I understand if centers are not correct then what's the point. I have read on this Forum the pros and cons of doing the holes first or last,
with mixed thoughts. We decided to do the holes on mine last just in case. That is another advantage of CNC accuracy as long as the programmer does his job lol
Post by NP317 »
djjh87 wrote: Sun Nov 27, 2022 5:29 am The rods turned out awesome. That task is coming for me soon also. Jim
Thanks, Jim.
Odyknuck
Post by Odyknuck »
Finished the domes up today. Only painting remains. I may decide to Powdercoat them as I have an oven to do it in. Waiting for the PRVs and the vent globe valve to come it to complete the actual steam dome.
Odyknuck
Post by Odyknuck »
Santa showed up early today. I'm a ways off from needing the fittings and valves however PM Research had a 15% discount sale, so I took advantage of it. I did however need the 1/8" NPT valve to finish up the Steam dome lid. Still waiting on the PRVs.
Reason: Photo Orientation
Odyknuck
Post by Odyknuck »
Worked on the main rods today. Did one side of each rod. Unfortunatly My Buddy had to go rescue his son from an oil pan stripped plug, Kids! lol
