Super Simplex
jock2000
Super Simplex
Post by jock2000 »
Hi I am about to order the drawings for the Super Simplex, do I need the original drawings as well?
Jim Stein
Prasat Thailand
Super Simplex
Builder01
Re: Super Simplex
Post by Builder01 »
Hi Jock,
The Super Simplex can be built without the original drawings. Although the original drawings are handy for comparison. Neither set of drawings is exactly complete. I can help you with any thing that has been left out, including the exact location for the valve motion brackets.
Are you located in the U.S., or, U.K? Your byline does not say where you are.
If you are in the U.S., this locomotive is easily regauged for 4-3/4" track, as this is exctly what I have done to make it so you can run it on the majority of tracks in the U.S. If you need a list of things to modify, including some modifications to the boiler, I can supply that.
Here's my website that I have dedicated to the Super Simplex: https://supersimplex.yolasite.com/
The Super Simplex is a great little coal burning locomotive and I would guess that hundreds have been built in England.
jock2000
Re: Super Simplex
Post by jock2000 »
Thanks for that, I'm in Thailand. Will order the drawings. I have all the Model Engineer issues for both locos and will order the drawings now.
Jim Stein
Prasat Thailand
Super Simplex
Builder01
Re: Super Simplex
Post by Builder01 »
If you have all the ME articles for both locos, that will go a long way towards helping you out. The text is particularly helpful.
You have been a member of this forum since 2014? That's a long time to be silent here. What has prompted you to finally post? And welcome aboard!
jock2000
Re: Super Simplex
Post by jock2000 »
I moved to Thailand 4 years ago. I left behind my 5" 9F chassis and a part built Sweet Pea. During lockdown I watched a lot of YouTube channels and got enthused again and started to fit out a workshop, needs air-conditioning here.
Jim Stein
Prasat Thailand
Super Simplex
jock2000
Re: Super Simplex
Post by jock2000 »
Super Simplex CAD modification
Jim Stein
Prasat Thailand
Super Simplex
Builder01
Re: Super Simplex
Post by Builder01 »
Your post says, "CAD Modification`. But, you did not say what you are modifying.
jock2000
Re: Super Simplex
Post by jock2000 »
I'm adding pony wheels making it a 0-6-2 I found an article in ME vol 178 adding pony wheels to an origionl Simplex design I'm adding them to a Super Simplex which has a longer frame.
Jim Stein
Prasat Thailand
Super Simplex
Builder01
Re: Super Simplex
Post by Builder01 »
jock2000 wrote: Sun Dec 12, 2021 9:54 am I'm adding pony wheels making it a 0-6-2 I found an article in ME vol 178 adding pony wheels to an origionl Simplex design I'm adding them to a Super Simplex which has a longer frame.
That's pretty cool! It is not in your screen shot of your monitor. Plus, I think the monitor shows the front end of the frames, not the trailing end where the pony truck would be positioned. You also left out the hole for either the steam supply or exhaust. I see only one hole in the frame.
jock2000
Re: Super Simplex
Post by jock2000 »
Still have a lot of drafting to do.
Jim Stein
Prasat Thailand
Super Simplex
Builder01
Re: Super Simplex
Post by Builder01 »
It's also possible to make chips instead of re-drawing every thing. I built my Super Simplex pretty much just as drawn. It steams great and runs well. My chassis was running on air in 9 months and ran on It's own steam in 23 months.
jock2000
Re: Super Simplex
Post by jock2000 »
It's one way I can check the layout, I haven't used imperial measurements since 1975, so have to relearn everything. Just finished reading all your blog posts, thanks for putting that together.
Jim Stein
Prasat Thailand
Super Simplex
