2 1/2" scale 4-6-0 build
Re: 2 1/2" scale 4-6-0 build
Cooked up some double cheese burger snifter valves that Greg called them in his article in 2002 live steam magazine.
Jim
Jim
No problems just solutions.
This blast stack casting is sold by a good friend of mine and here is his card and info I believe it will work .
I ran in to interference with my tie downs so I hacksawed off
On the outlet side I pocketed .25 deeper with a ball mill and a rough taper out. Not to much monkeying around don't want to push my luck. I cut my final pass with the ball mill inserted to the square side.
The intake ports are 3/8. I drilled with a 19/64 drill then 5/16 two flute end mill. Then backed out of hole to an 1/8 and cleanup exhaust side till bridge width is right then clean up outside to port width
Jim
Jim
The ports are complete.
So I moved to the blast stack and luck would have it the height of this casting fits the bill. I checked with a 1:3 and 1:6 so all was needed was to level it's mount. I will make a couple of nozzles of different sizes. This blast stack casting is very nice it is divided up about half way and a nice taper for half or more.
Jim
Jim
- Greg_Lewis
Have you thought about a multi-port nozzle? My memory seems to think there are advantages to such.
This ones for Greg I think being a tall stack loco it will fire good
Got a lot accomplished today. But one more chest to go.
I pop back in shop late afternoon and knocked out studs for 2nd chest. Maybe should knock out head studs while set up.
Getting close to splitting the cylinders .
Jim
Jim
Got a few hours in the last 2 days..
The front heads were a simple turn but the back heads were a head scratcher for a while.
I decided that the bore had to be first so there was casting left to clean up for the cross head bar slide boss.
