2 1/2" scale 4-6-0 build
Re: 2 1/2" scale 4-6-0 build
And last for now a big thanks to a fellow live steamer here on the chat for helping me get this sent to shapways.
I hope high temp paint or caliper paint will holdup. Jim
No problems just solutions.
Good weather has me out of the shop on property clean up and some fun also. Jim
My plan all along was to make the dummy rods adjustable and still will for the back axle. But I wanted to try to hit the mark before I made them adjustable. Put a sharp point on the tram, bored the big end slid that on the crank and with tram in center point of crank swing an arc across the center line. With a magnifier find the point and very lightly punch. Then with the magnifier find the point . Each side were separate. Well the stars aligned and I hit both of them with no binding. I decided my luck had peaked for the day so I pulled out the dynamo castings and started filling the flashing while watching football. Jim
Interesting technique.
New to live steam
Building 3/4” 4-8-4 Northern &
1” 4-6-2 Pacific
1” 4-6-2 Pacific
I guess I should have said just to be clear I set the tram to the center to center of the axles. But to do this you need to have the journal boxes pushed all the same direction .
Rough sawed 3/4" stock for the front side rods
The bottom rod shows what happens when you lose focus. I sawed most of the grease or oil pedestal off. I will build it up with weld about 1/8" or so. The last shot is the scene of the crime. Jim
1st rod profiled
Started to use a fly cutter to cut the Internal radius because I did not have the right size cutter and it grabbed which is the shinny spot. So I used a smaller cutter than the print called for. I will work on the other rod this afternoon. Jim
Nice sculpture!
That is what we do when making an operating steam locomotive...
Thanks Russ they went faster than I expected so far Jim
That end mill means business!
New to live steam
1” 4-6-2 Pacific
1” 4-6-2 Pacific
And you remembered right & left rod shapes!
Whew!
Whew!
