2 1/2" scale 4-6-0 build
djjh87
Re: 2 1/2" scale 4-6-0 build
Post by djjh87 »
I finally got the eccentric rods finished. The print called for cast iron which I did not have on hand so I fabed up steel ones which I had to bush.
No problems just solutions.
djjh87
Post by djjh87 »
Look what came in the mail. I know Anthony had a lot of trouble but the final product is beautiful.
djjh87
Post by djjh87 »
squaring up the smokebox
djjh87
Post by djjh87 »
Getting setup for first cut on the cylinder. I'm thinking once both halfs are bolted together I may have to extend depth of table to to get clearance to bore otherwise I may have to machine separate . Next half I will raise it up to get face mill instead of fly cutter to speed up things.
djjh87
Post by djjh87 »
Cutting a rough second square.
djjh87
Post by djjh87 »
Starting a match plate out of scrap plate.
djjh87
Post by djjh87 »
I could have stepped it off with the dials but the plate keeps me from making a mistake. 4 center holes drilled and reamed for dowels.
Second picture dowels in. Like a glove
Jim
djjh87
Post by djjh87 »
Here is the cylinders doweled and bolted.
A very satisfying accomplishment.
Now you can get busy with the machining...
djjh87
Post by djjh87 »
After an arsenal of squares, dividers and rulers and about
re re re repositioning. These rascals are (just guessing) 80 to 100 lbs. The saddle will be close, print called for 11"OD tube I'm using 10"pipe same as front of boiler 10.75" OD. I pulled front frame to fit.
Greg_Lewis
Post by Greg_Lewis »
Looking good. Part of the fun is figuring out how to get the job done.
As to the saddle, Gene Allen told me to just make a bed of JB Weld across the saddle and set the pipe into it. While that might work — Gene knew what he was doing — I used a shaper, swinging the shaper head in an arc across the saddle, the toolbit set to the required radius. Slow but it worked fine.
djjh87
Post by djjh87 »
Thanks Greg, I am haveing fun makes you think outside the box. A shaper would be a good option but no have.
No shop time till next week Drat
Jim
