Kevin sprayberry offset round end hopper build
Terr1bleone
Post by Terr1bleone »
After getting good ideas from all of the threads by carl and jack (and others) I've decided to post some of the builds I have been up to.
This is a laser cut and bent kit from kevin sprayberry.
First parts were some 3d printed details while I was waiting for the kit to arrive.
The kit arrives
Build start
Terr1bleone
Re: Kevin sprayberry offset round end hopper build
Thought I was doing well here.. till I realized 3 ribs were on the wrong side on each pannel and I cut them to fit.
And off come the sides again to try again.
Easy fix for the tig welder
All fixed now after a full day setback, back to where I was.
Terr1bleone
Starting to add detail
Under body
The kit calls for 1x2 rectangular tubing for the frame rail.
I decided to dress it up a bit.
Terr1bleone
Attaching doors
Fitting frame
Terr1bleone
Some more progress
Terr1bleone
Brake detail parts. 3d printed prototype for mock up.
Ouch, melted the bracket when welding the baseplate to the frame
Onto the lathe to try and save the body
A new base machined and ready to be mounted again
Mounted
makinsmoke
Post by makinsmoke »
Terrific build!
Just great work. Thanks for posting!
Did you print the brake parts or find them?
Tks,
Brian
Post by NP317 »
Nice detailing!
Terr1bleone
Mainsmoke, I printed them myself.
Thanks Russ.
- Mike
Terr1bleone
Brake line
Terr1bleone
Brake line pt 2
Now that I got that done time to move on to some minor things.
As it sits now
3d printed holder for different length rivets
Terr1bleone
Bettendorf trucks from Dave from mercer.
Opted to use ball bearings over Dave's bronze bushings
Finishing wheels
