John's Clishay build log
dakine
Re: John's Clishay build log
Post by dakine »
Next step is to prep boiler shell. (8" x 3/8 steel pipe) , install tube sheets and file welder. Then fab Bill Harris tube expander and expand pipes. Holes are reamed 0.002" - 0.004" larger than pipes. They fit in loose enough to "wobble" the other end an inch or so.
dakine
Post by dakine »
"find welder" - must know how to weld sheets to boiler shell much better than I can!
apm
Post by apm »
When you make the fire door weld it in at an angle so you can actually look in and see some of the fire. Years back I built one of those and where the tender sits from memory there's no good way to see into the fire.
dakine
Post by dakine »
Boiler about ready for welder. Need to install steel fittings so I can screw in brass fittings I guess. Not so sure about this task????
dakine
Post by dakine »
re: fire door mentioned above - yes, need to think that through... thanks.
dakine
Post by dakine »
re: fire box. This is a "Dry Leg" boiler. The separate fire box (6") is in photo above (July post) The fire box is designed so I can use propane as described above, and I will also fab an ash box as described in book. I am going to cut a 7" dia hole in bed, and use a "drop in plate" that is same size as the firebox id. (8"), and will have a square cut out for ash pan when using coal. This drop in plate will also have provision for the grate. I don't know how long a dry leg fire box will last but I have a second one on the shelf. When using propane, the burners are in the 7" cutout.
dakine
Post by dakine »
For the various fittings, I have found that a "Half coupler" is a good way to go. Available at McMaster Carr for $2.44 ea
1/8 NPT is 5/8 OD, 5/8 long.
dakine
Post by dakine »
Half Coupler
Pontiacguy1
Post by Pontiacguy1 »
Or you can buy regular length schedule 80 couplers and then saw them in half or part them in the lathe. My local hardware and industrial supply store stocks schedule 80 fittings, so it makes it a lot easier for me to do it that way. go with whatever works best for you.
dakine
Post by dakine »
sure - got it. I am learning as I go. Thanks
dakine
Post by dakine »
A friend in the Train Club gave me his old mill he no longer has a use for.
dakine
Post by dakine »
I don't know why some of my photos end up sideways?
