Allen models Fitchburg Northern build by first timer
mcjustis
Post by mcjustis »
Well, I got my plans the other day and made a start this morning. Got quite a bit done. This is my first loco build but I have been making i.c. and steam engines for years. I've been a machinist for a little over twenty years and a tinkerer most of my life so this is right up my alley. I have a very nice club just a few minutes up the road (Indiana Live Steamers) so hopefully will get over there this summer.
I plan on documenting the build on here. We'll see how it goes.
Thanks,
Martin
Greg_Lewis
Re: Allen models Fitchburg Northern build by first timer
Post by Greg_Lewis »
Welcome Martin! We're eager to watch your progress. And a good choice of engine. I think it is well proportioned and a good size. Not too big, not too small.
rmac
Post by rmac »
Wait a minute. You made all those parts in one day?
-- Russell Mac
mcjustis
Post by mcjustis »
Yep. Couple hours not including the time looking through the prints.
Martin
Post by Bill Shields »
Really?
What are you using to cut the parts?
mcjustis
Post by mcjustis »
Yes really using a waterjet. Takes a few minutes to generate the cut file, copy the part x # of times, tab together and bam. Easy peazy.
These are most of the sheet metal parts. All but the frame is stainless. I didn't have any 1/2" thick stainless so they're just a36 plate steel. I think I have all the 1/8" and 1/4" thick parts done. I still have to look through the plans a little more closely and see if I've missed anything.
I ordered the first couple sets of the castings from Allem models. Steve said he's out for a few more days but will get them out when he returns. If he ships as fast as he did the plans I should have castings in about a week and a half.
So let me start with what will I'm sure be a long list of dumb questions. On the plans the pistons and cylinder are both called out as 1 1/4, but if you look through Allen mdls site is shows 1 3/8" rings. Do most just bore out to 1.375? Is it just up to the builder?
Martin
Pontiacguy1
Post by Pontiacguy1 »
those cylinders will take the 1.375" bore, and that is what you need. if you use the smaller 1 1/4" bore, your locomotive won't have enough power, and will stall out with a heavy load.
mcjustis
Post by mcjustis »
Thanks for the help. I'll plan on the larger cylinder bores then.
Martin
mcjustis
Post by mcjustis »
Got the spring steel pieces all cut out and de-burred. Only about 3,543 parts left to go. I should be done by retirement.
Martin
Post by NP317 »
"I should be done by retirement."
Nope. There will always be something more to do...
milwiron
Post by milwiron »
I am so jealous.
Before I retired one of the departments I had under my supervision was the Toolroom which included a 7 x 14 foot working area, 5-axis, Omax waterjet.
I did a lot of the shop programming for it plus I spent many free hours on my personal projects... all before starting another loco in retirement. Of course now I'm 100+ miles away from it.
Geez I miss that machine.
Keep up the great work!
Denny
"Measure twice, curse once."
mcjustis
Post by mcjustis »
Got a few small parts cut this morning. I need to get going on some mill work on all the frame parts.
Martin
