Turning an Allen Ten wheeler into a Southern Pacific T1 class locomotive 2252
- makinsmoke
Re: Turning an Allen Ten wheeler into a Southern Pacific T1 class locomotive 2252
Laird valve guides!!
That is different than a laird though right? Not sure what the technical term is for the ones above, but definitely more common on older power.
- makinsmoke
The Laird has two bars one on top of the other above the cross head. The multi bearing has two bars side by side, cross head again below.
Grant,
Check your PM's.
D.
Check your PM's.
D.
http://www.precisionlocomotivecastings.com/
Building a 70 ton Willamette in 1.6"
Building a 80 ton Climax in 1.6"
"Aim to improve!"
"Mine is not to question why, mine is just to tool and die"
"Aim to improve!"
