Turning an Allen Ten wheeler into a Southern Pacific T1 class locomotive 2252
makinsmoke
Re: Turning an Allen Ten wheeler into a Southern Pacific T1 class locomotive 2252
Post by makinsmoke »
Laird valve guides!!
Berkman
Post by Berkman »
That is different than a laird though right? Not sure what the technical term is for the ones above, but definitely more common on older power.
makinsmoke
The Laird has two bars one on top of the other above the cross head. The multi bearing has two bars side by side, cross head again below.
Doug_Edwards
Post by Doug_Edwards »
Grant,
Check your PM's.
D.
"Aim to improve!"
