Nickel Plate 762
- JBodenmann
Re: Nickel Plate 762
Now it's time to form the upward bend. A tubing bender was used for this. The lower end has a 90 degree elbow. The last two snappies here show the exhaust line in place. There is a choke and a relief valve in the pipe. The pipe supplying steam to the pump has a drain, and another relief valve. Most of this baloney is under the running boards but you can still see it. There are still a couple pipe clamps to fit up here and there. I forgot to mention that this piping is 5/16". After the pipe clamps are fitted up the joints will all be soldered and then the whole mess will be prepped masked and painted.
Having Fun Here
Jack
Having Fun Here
Jack
Nickel Plate 762 ditch extension and ditch covers?
Jack,
In an earlier post you described piping on the starboard side as running under “…the feed water heater ditch extension … where the big cold water line goes up into the feed water heater.”
In the recent post you described on the port side: “The hot water pump has an exhaust line that runs forward. On the early engines it ran under the ditch cover and up into one of the exhaust ports in the stack.” The piping that you described is on the port side.
So, I’m confused (easy to be) regarding the “ditch extension” and the “ditch cover” . Can you elaborate?
Thanks for the tip on bending brass tube with the fine sand and caps on the end – easy-peasy now, having struggled before without using this technique.
Regards,
Andy
Regards,
Andy
Hello Andy,
may these documentations help understanding all that complex tubing?
Best regards
asteamhead
Best regards
asteamhead
- Attachments
Reason: Photo Orientation
- JBodenmann
Hello My Friends
Here are a few photos showing the piping for the Worthington feed water system. In the top photo the large water line comes from the tender on the fireman's side, and then forward across the trailing truck. This photo shows the ribbed hose connecting it to the centrifugal, or cold water pump. It then exits the cold water pump and travels across the front of the fire box to the engineer's side. This piping across the fire box was changed. The prototype had a union centrally located on the front of the fire box where our giant hands could not reach it, so the union has been moved closer to the edge where you can get at it. In the third photo the pipe pops out to the engineers side, turns upward, and travels behind the power reverse and under the running boards. It then turns upward into the feed water heater ditch as you can see in photo #4. The ditch cover is removed in this photo. There is not actually a feed water heater here, just a pipe. The pipe then exits the feeder heater ditch back on the fireman's side in a large 3/8" insulated pipe and travels to the hot water pump. On this side the ditch cover is in place. And lastly it exits the hot water pump and connects to the check valve. So there you go, a Worthington feed water system.
Jack
Jack
Hello Jack,
Watching your art of piping is just fun to us viewers
All the best by asteamhead
ditches and feedwater: Nickel Plate 762
Asteamhead and Jack,
Thanks for the explanations.
It had not occurred to me that the smokebox recess was the ditch...and the complicated systems to and through that ditch to preheat the water.
Regards,
Andy
Regards,
Andy
- JBodenmann
Hello My Friends
Here are some parts for a Barco flexible connector. These are used to connect the Nathan 4000 injector. Both the steam supply , and delivery pipe to the check valve use these. This piping will all be 3/8" tube. It will also be insulated. I have been waiting for these casting to finish the piping for the injector. They utilize a ball and socket with teflon ring seals. More to come.
Jack
Jack
- JBodenmann
Hello My Friends
Here are a couple more shots of the Barco fittings and the Nathan 4000 piping.
Jack
Jack
So what museum will this locomotive be displayed in?
It is going to run, a lot, mainly at LALS and RLS.
Jim Kreider
Jim Kreider
I may have to make a pilgrimage to LALS or RLS….
Mountaineer
Mountaineer
Would be cool to see at some Eastern tracks like mill creek or blue berry rr
