Nickel Plate 762
Re: Nickel Plate 762
Which is what I use...I am nowhere the craftsman that jack is and a spool valve was my cup of tea.
- JBodenmann
Hello My Friends
If there is interest I can make some cylinder cock control valves.
Jack
Jack
I would be interested in 2 cylinder cock control valves.
- Greg_Lewis
Why the different materials for different media? Wouldn't Teflon also work for air?JBodenmann wrote: ↑Wed Mar 02, 2022 9:37 pm Hello My Friends
This valve has a Teflon disc as it's set up for steam. Valves that I make for air have a cast iron valve disc.
Jack
Jack,
Love those tiny and precise valves
Asteamhead
Asteamhead
I would be interested in 3 valves.
Jim B
Jim B
Curious what price point you'd offer them at?
- JBodenmann
Hello My Friends
Well, it looks like I will be making some cylinder cock valves. As to teflon, versus cast iron for valve discs. I have found cast iron to be vary stable as a valve disc. These work well for air, operating on a bronze surface. These valve bodies will be bronze. I have made teflon valve discs for air, and they work well at first. But I have had teflon valve discs warp over time when used on an air valve. This doesn't seem to be a problem with steam, as the hi temp softens them, and the pressure will flatten them out on the valve body. When using a teflon disc, you must very gently chamfer the edges of the ports in the valve body that the teflon disc will be moving over. Otherwise it will cut the teflon valve disc. As to the cost of the valves, I won't know until I have made a batch of them. You don't really know the cost of something until they are finished and in the box. I am currently working on a batch of molds and some will be for the cylinder cock valves. No shortage of things do do
Jack
Jack
- JBodenmann
Hello My Friends
Been busy busy busy working on Jim's Berk. Mainly final fit up and soldering the joints on the piping made a while back. Also some new piping here and there. Then it all has to be prepped and painted. I have a gaggle of cool bits and pieces that have been drying for several days and it's now ready to be put together. The air compressors have been prepped, masked and painted too. Once they are bolted up the associated piping will have the final fit and solder. I solder all this piping with Stay Brite solder. In places where you can't solder, such as entering and exiting appliances like power reversers, feed pumps, and air compressors I will use teflon tape. Here is a photo of the air whistle. It's called that because it's a steam whistle, operated by air. Too much fun!
Jack
Jack
- Greg_Lewis
JBodenmann wrote: ↑Sun Apr 10, 2022 8:49 pm Here is a photo of the air whistle. It's called that because it's a steam whistle, operated by air.
So were they able to feather it like one with a pull rope? I'd hope so.
Why air rather than steam for whistle?
Mountaineer
Mountaineer
Looks like just the actuator is air operated to control the steam to the whistle.
