First steam locomotive build-3/4" scale Raritan
Re: First steam locomotive build-3/4" scale Raritan
the 4" is the larger pipe (IIRC)
the original size is no longer available
Actually...the original design called for 3 - 1/2” o.d. copper pipe. That is no longer available so Mr. Morewood came up with a revised design using the 4” o.d. pipe.
Keith
- Joe Tanski
The Book now has all the drawings for both size boilers and all the dimension changes to the cab and chassis and smoke box
To make the larger boiler fit perfect .
Tanski Model Engineering
Thanks, Gang.
Good to know.
Good to know.
3.5" copper pipe is still available its just hard to find, especially if you want less than 10 feet of it.
-Frank K.
You can get it from Reeves in the UK by the foot. $100 shipping to the USA plus about $75 / foot for the pipe.
Just my personal opinion.....but I think Raritan looks better with the 3 - 1/2” boiler.
- Joe Tanski
Yes it does, but it run's a lot better with the larger Boiler,more steam capacity
Joe
Joe
- Benjamin Maggi
Anyone have pictures with boiler sizes to compare visually?
I have lots of pictures of the original Raritan which is the 3.5 boiler...many of which as Bill Moorewood carrying it by the stack back and forth to the track...
Lets not forget that the Kozo A3 also has a copper boiler that was constructed from flat sheet.. If I remember correctly, very close in diameter to 3-1/2"? You can probably use all of his prints for the formers???
John
John
