3/4" Scale J1e
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Some time was spent this weekend working-playing, on the journal box lid master. Work sounds like drudgery...as this is so much fun I think play is more of a descriptive term. A while back I hadn't decided which journal box lids to make. I picked this one. At first glance I thought it would be difficult to make, not understanding the snap shut - snap open mechanism. I found a sectional view and realized it is an elegantly simple design as you will see as it goes together. As usual I will be making masters and then castings. Especially as there are twelve of the little fellows on the tender trucks. Here is an illustration from the 1941 Loco Cyclopedia. The journal box lid has three main parts. The main lid body, the hinge, both of which are visible. And on the inside there is a lever. One end of the lever is pressed on by a spring. The other end of the lever presses on a cam on the stationary part of the hinge where it attaches to the axle box. It's a very cool set up. Here is a start on the main lid body. Just free machining brass. This is the inside. Here it is plunked down on the axle box for a look. The lid is .070 overall thickness. The front wall is .040" thick. It is .850" Hi, and .830 wide. Here is a start on the raised rib that will surround the hinge. This rib will also get some bosses for the .048" pin that will hold the whole mess together. Here what will be the raised rib is sitting on the lid. Once this sub assembly is silver soldered in place, the flat part that is now on top will be machined away.
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Here is some more progress on the journal box master. Here the raised rip piece has been cleaned, fluxed, and held in place with frogs. As usual small pieces of silver solder have been placed here and there. And after soldering And here the part that joined the two ribs has been milled away.
- JBodenmann
Re: 3/4" Scale J1e
Now for some tiny parts that had me puzzled. These will be some bosses, that locate the pin, that holds the whole mess together.
The little rod with the hole drilled through is .090" Diameter. The hole is .049"
I had to think about these little pieces for a while. I often talk about a chess game, or a little puzzle and this is one of those instances.
Here the tube has been silver soldered in place.
After a swim in the acid pot the center of the tube was machined away.
Then the work piece was split down the middle.
- JBodenmann
Re: 3/4" Scale J1e
Here a recess is being milled. This recess will fit over the raised rib on the main lid body. After cutting the recess the same 1/8" end mill was used to part off the work piece.
See You In The Funny Pages...
Jack
Two tiny little parts, that will fit to another tiny part, that is part of another tiny part.
And here is how they fit in the overall picture. You can see how the recess fits against the raised rib.
And here they have been soft soldered in place. As the raised ribs were silver soldered, the little bosses were soft soldered so as not to melt the silver solder and disturb the raised ribs.
And here we have the mostly finished journal box lid. I say mostly finished as it still needs two more parts added. There is a raised area around the raised ribs and the start of one is sitting next to the lid. This will be shaped by hand using files, sandpaper, and the jewelers buffer.
Next time we will finish up the lid and start on the hinge.See You In The Funny Pages...
Jack
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Here the raised part has been partially fitted to the center rib. This is looking much better. Here they have been soldered in place. Tix solder was used for this final operation as it has a very low melting point. Here is the finished lid. It's had some work with a 1/8" diameter round ended end mill. Also some filing to massage the raised rib. And a mild zoom with the jewelers buffer. Now to make the hinge. This will fill the tapered slot in the cover. It will also fit under a pin through the bosses. Inside the hinge will be a spring, and a lever for the snap open - snap closed feature.
Too Much Fun!
Jack
Too Much Fun!
Jack
Re: 3/4" Scale J1e
Hello Jack,
Amazing brass work as always! And doing this another 11 times (or make wax casts?) ... forget about time just for a perfect look
asteamhead
asteamhead
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Thank you Asteamhead. You are correct, I will be making molds for the journal boxes as there are twelve of them. The hinge part has been started, here are some snappies. Here the general shape has been made and the hinge has been test fitted. I got busy and didn't get ant photos of making the slot for the pin. Here is the pivot part of the hinge. Basically a tube with two ribs.
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
The journal box master is just about finished. A few details remain like some lettering and filling here and there. The lid snaps open And snaps closed Time to make the molds
Re: 3/4" Scale J1e
I'd love to see how you make them too!
- Dick_Morris
Re: 3/4" Scale J1e
Nice work, as usual. I was wondering if you would be adding lettering and how you would do it. I never came up with a good way to apply little letters on my sand castings and didn't work it out until I started doing investment casting with the "waxes" made on a 3D printer.
- Greg_Lewis
Re: 3/4" Scale J1e
Many years ago, well before 3D printers, I found a local shop that made rubber stamps. I provided the artwork and they made just the rubber, without the handle. I also had them make it "right reading," as a stamp would read backwards if you looked at the rubber. Then I made a mold from that using hardware store silicone goop. I then filled that mold with JB Weld. Then I sanded down the backside of the JB Weld bit so it would lie flat on my pattern. It worked fine for what it was at the time.
- Dick_Morris
Re: 3/4" Scale J1e
I had that same idea. My sister owned a rubber stamp company at the time, but she was in Phoenix and I was in Anchorage and I wasn't successful in explaining, or she wasn't successful in understanding what I needed.rubber stamps
