EMD F7 in SCALE
Steggy
Re: EMD F7 in SCALE
Post by Steggy »
For those who are interested in the parts I used to make the class lights I've attached PDFs with the information. Any 10mm LED will work, or you could even attach short, stiff leads to an incandescent lamp and use that instead of an LED. Electronics distributors such as Digi-Key and Mouser stock the parts.
LED_lens_10mm.pdf
10mm LED Lens
(88.95 KiB) Downloaded 498 times
LED_socket_10mm.pdf
10mm LED Socket w/Leads
(38.98 KiB) Downloaded 455 times
ccvstmr
Re: EMD F7 in SCALE
Post by ccvstmr »
BDD...will add...
The HMC-461-XXX plastic lenses ARE fresnal lenses. Using an arbor to fit the lens over snugly...can spin these on a lathe to cut the original lens threads away and use the remaining disk for new/replacement caboose marker or classification lamp lenses. Carl B.
Steggy
Re: EMD F7 in SCALE
Post by Steggy »
ccvstmr wrote: Mon Dec 07, 2020 11:05 amBDD...will add...
Plus the lenses are available in a number of colors. I used the red ones as markers for my caboose, but with the screw-on socket for retention. With a 10mm, high-intensity, white LED they are visible at a good distance.
Glenn Brooks
Re: EMD F7 in SCALE
Post by Glenn Brooks »
Some years ago someone posted a very interesting thread about making fresnel lens by heating acrylic disks and pressing them into shape with a die he made up on his lathe.
I’ve been looking for it ever since, to no avail....
rkcarguy
Re: EMD F7 in SCALE
Post by rkcarguy »
Glenn Brooks wrote: Thu Dec 10, 2020 12:42 pm Some years ago someone posted a very interesting thread about making fresnel lens by heating acrylic disks and pressing them into shape with a die he made up on his lathe.
Glenn, I think someone posted that as a response in my signal thread? I can't seem to find it. There was also responses including one modeler that would turn the ridges into the plastic round stock, then part it off, flip it around in a fixture and cut the convex surface, then polish it all clear. Seemed like a ton of work but looked really nice.
Steggy
Re: EMD F7 in SCALE
Post by Steggy »
rkcarguy wrote: Tue Dec 15, 2020 4:59 pmThere was also responses including one modeler that would turn the ridges into the plastic round stock, then part it off, flip it around in a fixture and cut the convex surface, then polish it all clear. Seemed like a ton of work but looked really nice.
I recall that and was impressed with the results. Almost looked like the factory made them.
Glenn Brooks
Re: EMD F7 in SCALE
Yes, very slick method as I recall. I think the guy machined the die in a serrated, convex (concave??) shape, so that the plastic disks would conform to the true fresnel shape when they heated and pressed in the die. He also reported buying different color lens, white, red, green, etc and making any color he desired. Very cool stuff, and appeared simple to do.
I’ve searched for the thread with every key word I could think of, to no avail. It’s either been deleted, or lost in the volumes of generic, similar titles. Perhaps one reason we could use more well defined sub threads, or some system of standard code names to facilitate better searches and recall.
rkcarguy
Re: EMD F7 in SCALE
Post by rkcarguy »
viewtopic.php?f=45&t=105775&p=379957&hi ... es#p379957
This was the link for the lathe turned ones.
Note that for many lights, the lenses are actually clear and it's the bulb, or a colored shade behind the lens in the case of a searchlight signal, that provides the color. So the colored material may not be needed depending on what you are modeling.
I have some experience with heating and molding various plastics, and it's rather tricky. The material has to be just the right temperature. Too hot and it gets bubbles in it, too cold and it will crack when formed. Also, to come out with an easy no polishing needed finish, the mold you are pressing the plastic into would need to be polished as smooth as possible or you will be doing a bunch of it on the finished parts and might as well turn them from stock on the lathe.
rkcarguy
Re: EMD F7 in SCALE
Post by rkcarguy »
BDD, I'm curious what material your brake discs are made of? Steel? Cast iron? Stainless?
Steggy
Re: EMD F7 in SCALE
Post by Steggy »
rkcarguy wrote: Tue Dec 22, 2020 6:00 pm BDD, I'm curious what material your brake discs are made of? Steel? Cast iron? Stainless?
They are made of carbon steel and are modified Airheart go-kart rotors that came from Northern Tool back when they stocked them. This part looks as though it would be a good substitute.
Racie35
Re: EMD F7 in SCALE
Post by Racie35 »
Where can you get the cast nose piece ?
Steggy
Re: EMD F7 in SCALE
Post by Steggy »
Racie35 wrote: Mon Mar 08, 2021 9:57 pmWhere can you get the cast nose piece ?
Contact Dave Newell at Pike River for information—you can PM him here as well.
