Kombrink's American
Re: Kombrink's American
So...
The cylinder Cocks were a complete success. No more oil and water out the stack on leaving the firing bays.
The EE injector works as advertised. After no problems on three runs, it would not pick up on the last run of the day. The injector was hot to the touch and steam was coming out the water exhaust continuously. Everyone told me it was probably a bad boiler check valve but it would turn out to be the steam valve at the turret. It picked up a bur somehow and would not seal right. I replaced it with on from Blackgate's in England. I actually ordered three to have two spares in the future. Will try to re do the seat on the bad one.
The CO2 brakes were not successful. While they worked, they still used the gas too fast along with the fact that it only ran out when heading down a steep hill.
There was also the instance when the bottle became over heated when the car was out in the sun and the blow out disk on the bottle let go. Quite a show and noise. It seemed to impress everyone at that point.
I finished the season installing a Tom Bee compressor tank and battery to replace the CO2. I added an extra reservoir and a Tom Bee brake valve on the front of the tender. I then ran lines from the Box Car to and from the brake valve. This gave me a much more controllable flow of air to the brake cylinder.
The last run of the year was at Mid South. Much more enjoyable with brakes.
Charlie Pipes
Mid-South Live Steamers
Current Projects:
Little Engines American
Current Projects:
I mentioned the brakes going out on a hill. I should have stipulated the hill was at the Canton GA. track.
Actually I am very proud of the fact that the American made it to the top twice. Coming down was a rush.
This was the first time out with the full string of cars.
Charlie Pipes
Current Projects:
Current Projects:
much like flying....any one from which you return and walk away from is a good trip.
Very True also in the sense that every time you fly you discover something on the plane that needs to be fixed.Bill Shields » Thu Dec 12, 2019 7:59 am
Real Aircraft or Models for that matter.
One thing nice about live steam is that every time you run, you have something to fix for the next week.
Charlie Pipes
Current Projects:
Current Projects:
Nice looking train! And still on the rails...
In trying to add a little class to the American I have found a small print file for an old man. I blew the file up to 1.5 inch to the foot scale.
This is the results. I am building a small crate to put under him and will attach him to the back of the caboose.
Charlie Pipes
Current Projects:
Current Projects:
- Greg_Lewis
Awesome. We lack figures in our scale.
Greg:
Use mice.
Use mice.
I will be more than glad to send the STL format file to anyone that would like to use it. It can be scaled to the size you need it. The file is for a 2 inch figure but scales up nicely
Charlie Pipes
Current Projects:
Current Projects:
- Greg_Lewis
I like your printed man. I can see many more such good items appearing. They really add to the scale appearance of our trains.
Remembering when Matell Corp had Barbie Doll ditch Ken Doll and get a new boyfriend,
I read that someone videoed Barbie engineering a 1.5" scale diesel locomotive and motoring over Ken, cutting him in half!
Anyone know if true, and is so where it might be found?
Or just doll-sized urban legend.
If not true, Captain Picard might suggest: "Make it so!"
- Dick_Morris
Many years ago a friend adapted a Barbie to serve as engineer on his 1-1/2" scale Mike. He always referred to the engineer as a Barbie that had had a sex change operation.
Ideal (I think) made a series of character dolls around the 1970. They included Jed Clampett, Ellie Mae, Jethro, Maverick, and James West and are very close to 1-12" scale. I found several on Ebay years ago and have them spirited away.
I like your old man model, but can't figure out where I would put him. With 3D printing someone with a lot of patience could populate a passenger car with passengers. By mixing and matching body parts and heads and sticking them together and using different paint schemes, one could cut the number of actual unique models to just a few.
For someone with a lot more free time than I have, I've seen a Youtube video that gives information on 3D scanning and using free software to creating a 3D model which can then be printed.
