2 1/2" scale 4-6-0 build
Re: 2 1/2" scale 4-6-0 build
Here is .my solution to alignment and tie down. I think the most used machine in my shop is my Brown and Sharpe horizontal mill.
Jim
Jim
No problems just solutions.
The finish came out nice.
This picture was not the final pass.
Had to fab up a super fly. Worked good but .01 a cut at 40 RPM took a while.
Jim
Jim
Nicely done!
Thank you Russ.
In my mind I was going to make a cutter to run on the horizontal arbor with over arm support but the diameter was just a little big.
Started on steam chests but on hold now the vertical mill 2 speed switch is acting up so I ordered one. I hope it's that and not the motor.
Jim
Jim
A little more detail on the last post
Eye up castings and mark center
Drill and ream a shallow 1/8" hole for pin both ends
Notice in previous pictures the chest is on match plate I used for cylinders . Drill pin location holes in plate
Then all machining and drilling are matched
While vertical mill is down I started the recesse of .060" for steam chest
One chest casting was a little catawampus which caused it to be a pain to deal with but all is well so far.
- Dick_Morris
I've seen a way to apply an outboard bearing on a boring set up like you used. A bracket is attached to the table to support a pillow block. There is a true running extension on the boring bar which is a close fit in the pillow block bearing and the extension is allowed to slide in the bearing. As in your set up the X and Z axis are locked and only the Y moves. Although not as good as an overarm supported bearing, it should add a lot of support to the cutter.
The same idea can be used on a vertical mill with the head turned so the spindle is parallel to the X axis. The pillow block would be mounted to the table with a bracket to support the outboard end of the boring tool. On a Bridgeport type mill one should be able to use the various head adjustments and bore a fairly long hole using the table X feed. (On mine I would probably have to relocate the switch to improve the clearance.)
Hi Dick
I appreciate the Info. I had thought of that but didn't have the y travel to get the boring bar and the suport on the table. Turning the fixture for the x axis and using the universal head the center's were farther apart than the travel .
There is counter bore in there. Forgot phone (camera) at house when I returned to shop so not too many pictures
The gland face profile is just sawed and sanded and aligned by eye for bolt location kinda gives the look of a casting.
