Hammer,hammermill wrote:good to hear thoughts were on a similar path. if all the jacks come from the same place it should be fine
as a note over the years i have found humongus cylinders on the backends of plastic extrusion presses that are no longer being used. 12 inch cylinder, 18 inch stroke 4 inch piston all you need to do is add a pump.
You were in FREE CYLINDER HEAVEN.
Ken.
