Brown & Sharpe Vertical Mill
I have been using a 1919 #2 vertical mill for about 8 months. It takes the B&S 21 spring collets in the spindle. I just noticed that the collets load into an intermediate "holder"...would this be a 50 taper? What ever it is, its bigger than a 40. There is no drawbar, so it would apear to be held by fit alone. Does anybody know about these features on this machine? If it is something like a 50 taper tool holder, I am also seeking advice on its removal for mounting larger cutters.
Re: Brown & Sharpe Vertical Mill
Not familiar with that particular machine, but I would be willing to bet it isn't a 40 or a 50 taper. Probably more on the lines of a B&S taper....
BP 2j vs, SB lathe, W& S #4 Turret lathe, Maho 600P
Does anybody know what year they standardized tapers?
aaron
Shouldn't have too much trouble getting 21collets. They've been used in B&S screw machines.
In the B&S handscrews I have, they sit in a sleeve that slides inside the spindle toward the nose cap to close the collet.(A little useless info)
As for the "holder", a 50 or other 3.5"/foot taper needs to be held in - normally with a drawbar.
The B&S tapers @ .5"/foot, are self holding, and were used in most domestic mills around that time.
bc
bc
BC
I have a "Advanced Machine Work" book, Copyright 1910 tru 1930 that show a drawing of a milling arbor that is B&S taper and is tang driven. Maybe someone has made an adaptor (B&S taper, tang driven to #21 collet) for this machine.
Hope this is some help.
Lou
Lou
