Parts availability for not so common mill/drill
Re: Parts availability for not so common mill/drill
I checked some tangless MT2 tapers. Mostly a bit over 15 mm at the small end.
Looks like the closest I find for a spec says it's just over 14 mm, 0.572", so you could put an M14 thread in it but it wouldn't last one use. The M10 mention looks to be"standard" metric.John Hasler wrote: ↑Mon Apr 26, 2021 9:50 amShould be about 15.5 mm but there seems to be no formal standard for tangless Morse tapers.
