Ring light
Ring light
Post by Bill Shields »
Anybody out there using a SELFIE RING LIGHT on their mill?
Bought a cheapie 8" diameter to play with..seems to give good light..just need to play with a few mounting ideas.
Know it is going to get hammered by chips..but for the $ as an experiment...
Glenn Brooks
Re: Ring light
Post by Glenn Brooks »
Bill, don’t have a ring light, but did buy a couple of small oblong LED “spot” lights that I found on Amazon. I use two of these on my Bridgeport clone, one on each side of the quill, and another on my Burke #4 horizontal mill. I tried these out as an experiment, as I thought I would need to use the round lower part of the quill to mount a rotating dial indicator to indicate parts on the robtab.
They Work very well. Quite glad I tried these out.
10KPete
Re: Ring light
Post by 10KPete »
I have eight of those lights like Glenn's on various machines. I love 'em!!
Pete
Just tryin'
shootnride
Re: Ring light
Post by shootnride »
I made one of the LED ring lights for my mill and I am not very pleased with it. It is very bright, but the problem is that as the quill is lowered, it blocks the light. I will likely go to something like Glenn has put on his machines. Photo attached.
Ted
jcfx
Re: Ring light
Post by jcfx »
The ring lights look cool on a mill but in practice they don't work well when you get closer
to the work as Ted pointed out, I had ordered a few sets of halo lights for cars to try, and
I decided to go another route because of the dim spot the ring light generated as the quill got
closer to the work.
I wound up like Glenn getting 2 flexible goose necked lights but from a sewing machine
supplier ( about $20ea ) and wired them together, they're pointed about 45º on each side
towards the work and have a mag base that I customized to attach to a sheet metal access
cover behind the quill on my PM 935 mill.
They work well, fully adjustable positioning and not too bright, each of the lights retain their individual on/off switches
so I can use both ( always ) or either one.
Re: Ring light
Good info .was actually thinking of mounting the ring light on the quill..but decided was not practical.
jcfx
Re: Ring light
Post by jcfx »
For me it would have meant making a whole new clamp collar for the spindle, and making some sort of reflector
to 'aim' the LED's on the ring light so that they would all shine on one spot. Too much trouble for what it had
to do. This is my setup with the sewing machine lights, I'm very happy with it.
Re: Ring light
I ordered a set of the sewing machine lights.
Nebodywannaringlite?
Re: Ring light
I quite like the sewing machine light. 2 for $16 delivered.
thx 4 suggestion.
Re: Ring light
Post by John Hasler »
Where did you get the sewing machine lights?
Re: Ring light
Amazon
EVISWIY Sewing Machine Light LED Lighting (30LEDs) 6 Watt Multifunctional Flexible Gooseneck Arm Work Lamp with Magnetic Mounting Base for Workbench Lathe Drill Press
Re: Ring light
Thank you.
