Milling machine soft jaws
Mr Ron
Post by Mr Ron »
Are aluminum soft jaws on a vise used the same as on a lathe? In other words, do you machine the jaws so as to hold a part for repeatability?
Mr.Ron from South Mississippi
Re: Milling machine soft jaws
The options are yours. They are commonly contoured when used with a CNC, and there's no reason why you can't do the same thing on manual machines, although complex profiles limit the ability. For simple configurations, you can use a milled pocket as a stop as an example, or create clearance for a projection that would limit, if not prevent, holding an unusual part in hard jaws.
Armed with that thought, one of the advantages of using aluminum jaws when milling is that you can machine away a part of the jaw when gripping unusual parts. I did that when I machined this latch, of which I had to produce 200 pieces to fill the contract. The latches are small. The spike shown below them is a common straight pin. The image was created with a scanner with the parts placed on the scanner bed. That's why they appear to be floating.
Key to success is one's imagination. There are no hard and fast rules. That's why soft jaws present so many advantages.
I have a habit of using jaw height parallels when gripping parts that can't be held in straight jaws. That, too, expands one's options, so keep that in mind when you have a part to mill that isn't friendly towards hard jaws. Again, use your imagination.
