Earlgo,
Thanks for posting your picture.
I'm familiar with machines with the trough, although my personal experiences came from larger machines (think K&T). What surprised me was that BP offered the troughs. They must be relatively scarce.
Vise Identification
Re: Vise Identification
I have a vise identical to the one in the first post, but it has Bridgeport cast into it. My Series II Special Bridgeport has the half moon troughs in the table.
Nyle
Nyle
Harold: Moore tool co said that Producto bought Moore Tool in the 40's and all the old info was lost. They did say that the Producto machines made a lot of typewriter components.
Spro: Here is a better pic of the "Accu-Lock" vise that I think I got from Travers Tool. The coolant channel and exit weir can be seen much clearer. --earlgo
No idea, but I remember it being in a friends shop in the early '80's. It was then traded to another friend that traded it to me.
Thanks for that. I did a search and found a few images. Makes the mill look like an industrial rated machine. I also noticed that the heads have considerably more horsepower. A much more robust machine than the ones I've owned.LIALLEGHENY wrote: ↑Sat May 25, 2019 9:52 pm My Series II Special Bridgeport has the half moon troughs in the table.
Harold,
Of the newer Bridgeport models.....Bridgeport made the Series 1, which is the standard 2 HP mill. They made the Series II which was the 4HP version with power feeds on all axis, a 40 taper spindle and a 58" long table. It has a much larger / taller base. The hand wheel for the x-axis is located diagonally from the saddle . I have the Series II Special which was the Series 1 head and ram, mounted to the Series II base. It has the 58" table but the hand wheel / power feed is on the end of the table like the Series 1 . It is a nice machine when you have taller parts , but small parts clamped to the table you can't reach even with the quill fully extended. I usually keep my Kurt vise with the swivel base on it which makes it usable for smaller parts. The other nuisance is having the handwheel on the end of the table...your constantly back and forth if your moving the table and trying to eyeball your position. It has about 33" of travel in the X ( which I believe is about the same as the newer Series 1 machines with the 48" table) but is has 15 " of travel in the Y which is quite handy. It also has air assist on the knee.
Nyle
Nyle
Thanks, Nyle. I've never explored the Series II BP's, so the information is welcome, and interesting.
The description you offered of the X axis handwheel was a feature on the Gorton 9J mills. The only negative I can think of is that the dials read backwards, so it was a little confusing if you weren't real familiar with the machine. That was due to the use of a set of bevel gears to connect the angular handle to the screw. I suspect that it would be second nature for the guy who was assigned to the machine, though. Much more convenient than having to walk to the end of the table to turn the handle.
I like the idea of a longer table travel. I've run numerous jobs (not commercial work---just home projects) where I've had to either move the part, or swivel the ram, so I could complete a long cut.
