I have a early 90's vintage Well Setting milling machine. This is the typical 16 speed step pulley, 9"x 42" table Taiwanese mill. I am trying to replace the switch with one off of a Jet JTM-1 milling machine. I thought I had good pictures of the switch jumper configuration, but didn't. I removed a couple and now don't know which way they go back. Does anyone on this forum have a Jet JTM-1 mill that they could take a picture of the switch?
Thanks,
Mark Hockett
I need help with a mill switch
- Mark Hockett
Re: I need help with a mill switch
I have a Jet mill that I think fits the bill, will look tomorrow.
- Mark Hockett
Mark,
Here are some photos from an Enco 3 phase, 2 speed motor. If they are close, I will try to get more detail. I also have the wiring diagram, could send that as a pdf.
- Mark Hockett
Russ,Russ Hanscom wrote: ↑Sun Mar 31, 2019 3:09 pm Mark,
That one is quite a bit different from mine, thanks for the picture.
Mark Hockett
Mark Hockett
No single speed.
- Mark Hockett
