Toyo Sakai ML-360 lathe... i need help...:)
xzsawq21
Re: Toyo Sakai ML-360 lathe... i need help...:)
Post by xzsawq21 »
Does anyone here have a Toyo/Sakai/Manix ML-360? I have a question! how much is the thread size of the screw in the middle of tool post?
rmac
Post by rmac »
You can get an operator's manual and a parts manual for that lathe here. With any luck, these will answer your question about the screw, and maybe also help you find the accessories you were asking about a few days ago.
Good luck!
-- Russell Mac
xzsawq21
Post by xzsawq21 »
rmac wrote: Tue Mar 01, 2022 3:57 pm You can get an operator's manual and a parts manual for that lathe here. With any luck, these will answer your question about the screw, and maybe also help you find the accessories you were asking about a few days ago.
Good luck!
-- Russell Mac
I have checked the below document before:
https://s3.amazonaws.com/rgmorton/Sakai-Manual.pdf
But there is no details in the manual.
