Why 29.5 degrees
Re: Why 29.5 degrees
of course there is also the 'stagger cut' method used by newer controls...
cut on the left flank
next cut on the right flank
next cut on the left flank
get to bottom...eventually
depths calculated based on constant volume of metal removal based on volume to be removed by first infeed.
I still hear my shop teacher (Mr.K) drumming it into our heads back in the early 70's "Set the compound rest at 29.5 deg. towards the tailstock to cut threads" I've been doing it ever since. I miss that guy.
Because threads can be generated with the tool upside down or right side up, with the machine operated in forward or reverse, depending on the thread in question, it's NOT a good idea to set the compound towards the tailstock for all occasions. It's also a good idea to make reference to the location as if viewing hands of a clock, to avoid choosing the wrong markings. Not all lathes are marked such that the proper angle is 29°30'. The marking may read 60°30' when you are set properly.
When feeding with the compound in machining threads, the important message should be that the compound should feed the tool in the direction of the cut. That means that the compound may be set at either 5:00 or 7:00, depending on whether you are cutting towards the tailstock or the headstock.
If the improper location is chosen, you run the risk of cutting pressure moving the carriage away from the leadscrew. If it remains there constantly, no big deal, but if it wanders between the two flanks, a drunken thread is the usual outcome. The ideal situation is that the cutting pressure keeps the leadscrew loaded, and that is accomplished by feeding the threading tool in the same direction the carriage is propelled in the cut.
Joe Pieczynski did a great video explaining this
https://youtu.be/PnH_oeOUps4
Sent from my SM-N975F using Tapatalk
Harold wrote:
This setup worked for me while threading toward the tailstock with spindle reversed. --earlgoWhen feeding with the compound in machining threads, the important message should be that the compound should feed the tool in the direction of the cut. That means that the compound may be set at either 5:00 or 7:00, depending on whether you are cutting towards the tailstock or the headstock.
Our shop lathes did not have reverse and neither does my home lathe. 29.5deg. towards the tailstock still holds true 60 years later.Harold_V wrote: ↑Wed Feb 16, 2022 4:38 pmWhen feeding with the compound in machining threads, the important message should be that the compound should feed the tool in the direction of the cut. That means that the compound may be set at either 5:00 or 7:00, depending on whether you are cutting towards the tailstock or the headstock.
0
Hi Guys, made this new spindle today for my cross slide on my lathe, original was worn where I use it most.
Used 14mm drill rod, aka silver steel and ground the profile 30 degree trapezoidal thread.
Used the tool upside down and lathe in reverse, only downside I could not use travelling steady, tool forces the work piece down so took small cuts.
Silver Steel machines nicely and achieved a nice finish and accurate.
My compound graduations only go to 45 degrees each way so I used my vernier protractor to set the compound at 14 degrees from chuck face
I bored out my cross slide nut and silver soldered and aluminium bronze slug which I bored to size and tapped with a 14mm x 3mm LH tap.
Next time I will use phosphor bronze ,aluminium bronze is extremely hard to tap but long lasting, thought I was going to break the tap but got it through in the end.
From previous post.
Won't let me attach photos.
Yes, it does. So long as the cut in question is taken towards the spindle. If it is taken towards the tailstock, you are not using acceptable procedure, and that's fact. Generate a left hand thread that way and tell me how it goes. Shift the compound to 5:00 and I agree with you.
Like it or not, if you advance the tool in the opposite direction of the feed of the carriage, you are subject to a drunken thread.
Industrial machines without reverse? Are you sure? What period of time would that be? I started in the shop (in industry) in 1957 and do not recall ever seeing a lathe that didn't have reverse capability. I do admit, the vast majority of the machines in question did NOT have threaded spindles, although even the threaded spindle lathes in the shop in high school had reverse. A shop full of old LeBlond short bed lathes.
How large are they? You must use good judgment in posting picture. They are best posted no larger than 1024 x 768 pixels. If yours are larger, yeah, the board will reject them, just as it should.
If your pictures are not unreasonably sized, please detail the problem you're having. We'll try to help.
Hi Harold, 9.7 MB, one photo.
