Hmmm. Interesting comment on the Monarchs. The shop in which I was trained had two of them, but I don't recall if they had the reverse switch, or not. I would assume that if they had the cam lock spindle, they would have had. The one thing I do recall is that they were geared very slowly, not made for the use of carbide. Killer rigid machines, they were.
Help Wiring Lathe
Re: Help Wiring Lathe
Harold the Monarch's have helical gears and I don't think they were designed to run in reverse with the opposite thrust on the drive shafts, not sure, maybe someone can enlighten me.
There was a war going on so maximum production going forward!
This is one of the reasons I following more than what immediately interests me. I ran a lathe at about 14 but my career went in a different direction.
I've never run in reverse. I read about threading from the headstock out so you can thread to a shoulder. What else do you do?
Put a permanent cut off tool on the back side
Unscrew a tap from a hole
Unjam a drill
Unjam a drill
Threading, without a dial!
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
It's really unlimited. Anything you can do forward can often be done in reverse, when there's a benefit in doing so. One of them that is really useful is polishing. Running both directions allows polishing over an interrupted surface without excessively degrading the edge. Both edges share the degradation, however, it isn't eliminated.pat1027 wrote: ↑Thu Feb 24, 2022 4:58 pmThis is one of the reasons I following more than what immediately interests me. I ran a lathe at about 14 but my career went in a different direction.
Having reverse on a lathe is much like having a microwave oven. If you've never used one, you don't really miss it, but if you have and it is then taken from you, you miss it terribly.
Look at reverse on a lathe as an added feature that makes the machine far more useful. It does. You just have to understand when and how.
- Location: The Warm Arizona Deserts... Phoenix to be precise...
Here is a video that learned me how to wire reversible motors to a drum switch.
It is a little slow... learning to draw the diagrams simplified everything for me.
Heck I drew the 6 dot pictures and wired a motor this afternoon.
https://www.youtube.com/watch?v=JKXwXLEaXek
Oh yeah... in reverse a chuck could come unscrewed leave the general area of a lathe... be careful
