I need help
Re: I need help
Post by John Hasler »
But it doesn't have to be nearly that pretty (otherwise mine wouldn't work).
Russ Hanscom
Re: I need help
Post by Russ Hanscom »
Might consider a new ring with extra material on the outside for support, or a second ring temporarily attached to the outside - something to provide support, as the ring you show is way too flexible for the operations you want to undertake.
