Estimating chuck speeds
I put a small yellow dot sticker on my lathe chuck and then used a tachometer app on my Iphone to estimate the chuck speed. I'm not convinced that the results were all that accurate. I don't have a belt/speed chart for my lathe. Are there any good methods to figure out how fast your lathe is spinning? Thanks.
- tornitore45
Re: Estimating chuck speeds
Look at the Motor Nameplate it shows the RPM most likely 95% x Line frequency X 60 / No of Pole pairs (either 1 or 2)
Typically 1750 RPM
Then measure the pulley Dimeters or gear ratios.
Try a reflective sticker possibly on all jaws
An unsophisticated app may get confused by the flicker of the jaws and count Jaws/minutes instead of RPM or be so crappy to just dream up some number since crappy software is the rule rather than the exception.
Typically 1750 RPM
Put a piece of 2" black pipe or similar in the chuck. Put the sticker on that.LouStule wrote: ↑Tue Sep 15, 2020 5:51 pm I put a small yellow dot sticker on my lathe chuck and then used a tachometer app on my Iphone to estimate the chuck speed. I'm not convinced that the results were all that accurate. I don't have a belt/speed chart for my lathe. Are there any good methods to figure out how fast your lathe is spinning? Thanks.
The app is basically a strobe light that you adjust with a slider until the rotating dot appears stationary and then the app displays the speed. Maybe I should borrow my buddies real strobe light and see if I can make my own belt/speed chart.
Good idea!John Hasler wrote: ↑Tue Sep 15, 2020 7:09 pmPut a piece of 2" black pipe or similar in the chuck. Put the sticker on that.LouStule wrote: ↑Tue Sep 15, 2020 5:51 pm I put a small yellow dot sticker on my lathe chuck and then used a tachometer app on my Iphone to estimate the chuck speed. I'm not convinced that the results were all that accurate. I don't have a belt/speed chart for my lathe. Are there any good methods to figure out how fast your lathe is spinning? Thanks.
Welll according to the pictures you posted of your lathe in the other thread you HAVE a speed chart!! With standard pulley setup those lathes went from 28 to 2000 spindle RPMs. 2 ranges of motor to countershaft and 4 on the spindle plus backgear.
www.chaski.com
- tornitore45
A strobe light can give harmonic results. The dot is steady at the RPM but also at 2 X RPM
20 Bucks on Ebay, LCD display with a magnet and sensor.
Use this on my Lathes and Mill, all have VFD'S.
Easy.
Easy.
Are you sure you are looking at my lathe? I don't see it anywhere. Plus, I want to verify the chuck speed at different belt/pully arrangements. Thanks.John Evans wrote: ↑Tue Sep 15, 2020 9:06 pm Welll according to the pictures you posted of your lathe in the other thread you HAVE a speed chart!! With standard pulley setup those lathes went from 28 to 2000 spindle RPMs. 2 ranges of motor to countershaft and 4 on the spindle plus backgear.
Found what? Do you have a link?
I think the search term is
hall tachometer
and a quick demo (there is another yootoob video showing a complete install on a mill)
https://www.youtube.com/watch?v=6AFuz_HkO8M
hall tachometer
