There are actually several (mostly from China) Easy search.
Estimating chuck speeds
Re: Estimating chuck speeds
Thanks. I mis-posted. I was actually talking about the spindle speed on my mill. Thanks everyone for the great info on this board.John Evans wrote: ↑Tue Sep 15, 2020 9:06 pm Welll according to the pictures you posted of your lathe in the other thread you HAVE a speed chart!! With standard pulley setup those lathes went from 28 to 2000 spindle RPMs. 2 ranges of motor to countershaft and 4 on the spindle plus backgear.
AH ! yes that do make a difference ! LOL Those no contact Tac's work great have used one for years.Thanks. I mis-posted. I was actually talking about the spindle speed on my mill. Thanks everyone for the great info on this board.
www.chaski.com
- neanderman
Just bear in mind, with v-belts, the ratio formula is not direct -- do an internet search on "v belt pulley ratio calculator".tornitore45 wrote: ↑Tue Sep 15, 2020 6:33 pm Look at the Motor Nameplate it shows the RPM most likely 95% x Line frequency X 60 / No of Pole pairs (either 1 or 2)
Typically 1750 RPM
Then measure the pulley diameters or gear ratios.
Otherwise, Mario covered it. It's all math, and can be calculated.
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Atlas 618
I just glued a neodeom miniature magnet on the top of the final drive pulley and set the hall effect sensor in close proximity and works great, it has an inbuilt led which flashes everytime the magnet passes the sensor to indicate it is functioning. Great for VFD.
