Bob D. wrote: ↑Mon Sep 14, 2020 8:00 am
You should be getting another screen..... Is the edit key on? Not sure if that limits access but it might.
I'll dig out the Operators Manual and see if there are clues there.
Here is a page on SFP
Nothing happens, no page is shown to me, just "beeps" the key and nothing changes.
Even in program editing mode, I tried. I tried with the CTL key together and it also doesn't work, as it says in the manual, just press to work ...
Do you have the key for the switch on the operator panel? It's not there in your panel picture. Open the panel and jump the two wires on the key switch if you don't have the key.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
Bob D. wrote: ↑Mon Sep 14, 2020 8:55 am
This key:
If this is not the case, I will have to ask maintenance to open the panel if this is the case.
Yes, that one. If nothing happens jumping the wires together try lifting one wire. I don't remember if locked is an open or closed contact. Generally it is open to be locked.
Pretty sure this is your access problem.
3/4" Hunslet 4-6-0
Bob D. wrote: ↑Mon Sep 14, 2020 9:21 am
Ok, I'll try. I looked for her original key and I didn't find it, but I already activated the maintenance, they will look after lunch. I hope that's it.
