Atlas 3996 Quick Change Tolerances
ryanDeVries
Post by ryanDeVries »
Hello,
I am rebuilding the quick change gearbox for my Atlas lathe. I am trying to what the tolerances should be for the bushings for the gears on the 1/2" shaft. The two compound gears and the single gear. They seam quite loose in mine, I don't know if I should replace the bushings or not. Does anyone know of tolerances for the parts in the quick change gearbox?
John Evans
Re: Atlas 3996 Quick Change Tolerances
Post by John Evans »
Don't think there is a published spec for that but as new I would expect about .001-.0015 .
www.chaski.com
ryanDeVries
The diameter difference I have is 0.010 inches.
John Evans
Tooo loose ,new bushing time.
www.chaski.com
