...and I'm ready to go on a date with Jeri Ryan. Doesn't mean it will happen.
NEWLY-ACQUIRED JET 1236PS
Re: NEWLY-ACQUIRED JET 1236PS
We were commenting about your lathe. We share that experience. If lefty, your chuck will spill out and score the bed.
- liveaboard
Lefty Righty China Taiwan... getting into forbidden territory!
Sometimes spro blathers...liveaboard wrote: ↑Wed Aug 19, 2020 6:19 am Lefty Righty China Taiwan... getting into forbidden territory!
The lathe's documentation is correct. It is indeed a 2-1/4" × 8 TPI spindle. See below.
That's a good thing!
Yep! Beats trying to find things to fit an oddball spindle.
The vendor from which I got the collet chuck and backing plate was playing doubting Thomas when I said it appears the backing plate has a bad bore. I sent him the hi-res versions of the above photos, which should convince him to replace the backing plate.
Hmmmm. That just may backfire on you. The image seems to indicate that the lead is not correct. Being 8 pitch, each thread should intersect the 1/8" lines on your ruler without gaining or losing. Unless it's an optical illusion, it appears that's not the case, and would easily explain why a proper pitch doesn't fit all the way.BigDumbDinosaur wrote: ↑Thu Aug 20, 2020 11:13 pm I sent him the hi-res versions of the above photos, which should convince him to replace the backing plate.
How loose are the fittings that go all the way? Do they start out loose, then get somewhat tighter as they advance? It's entirely possible that there has been compensation for a less than ideal lead. Crazy as it may sound, the thread indicates it may be 3mm pitch, not 8 pitch.
You are seeing the effects of the camera being set in "macro" mode in order to get the close-up—the lens was about two inches from the subject. Depth-of-field distortion, which is due to the relative focal length being longer near the edges of the image as compared to the center of the image, becomes pronounced at such a short distance.Harold_V wrote: ↑Fri Aug 21, 2020 3:17 amHmmmm. That just may backfire on you. The image seems to indicate that the lead is not correct. Being 8 pitch, each thread should intersect the 1/8" lines on your ruler without gaining or losing. Unless it's an optical illusion, it appears that's not the case, and would easily explain why a proper pitch doesn't fit all the way.BigDumbDinosaur wrote: ↑Thu Aug 20, 2020 11:13 pm I sent him the hi-res versions of the above photos, which should convince him to replace the backing plate.
The backing plate in question runs on to the threads almost all the way and then abruptly stops. If it were a thread pitch mismatch I would expect the backing plate would gradually become tighter the further it was advanced on the spindle. I've got two other backing plates that were specified as having 2-1/4 × 8 TPI bores, both of which fit the spindle.How loose are the fittings that go all the way? Do they start out loose, then get somewhat tighter as they advance?
Here's another image of the thread measurement. It's a little washed-out, exposure-wise, but has a little less depth-of-field distortion.
So the optical illusion won the battle!
I'm not a fan of threaded spindles, and this is a good example of why. I'm also known to reverse my machine under adverse conditions. Not a problem with my Graziano, as it has electromagnetic clutches and a D type spindle. A real problem when one has a threaded spindle, but one simply works accordingly. No big deal, really.
Mean time, good luck with the machine and the replacement faceplate.
- liveaboard
Since I went to a VFD, the chuck pretty much stays put when reversing; the vfd slows down and reverses much more gently than a paleolithic motor.
'Fraid so.
I'm no fan of them as well. When I put a chuck, face plate or other attachment on a threaded spindle, I give it a good spin with my hand to make it seat hard against the spindle shoulder. Fortunately, I've never had anything unscrew itself from the spindle. That said, I'm cautious about reversing a lathe with a threaded spindle. I have no desire to study chuck ballistics.I'm not a fan of threaded spindles, and this is a good example of why. I'm also known to reverse my machine under adverse conditions. Not a problem with my Graziano, as it has electromagnetic clutches and a D type spindle. A real problem when one has a threaded spindle, but one simply works accordingly. No big deal, really.
The vendor is taking their time about righting this problem. I bought it through their eBay store, which means I could get unpleasant about it if they don't soon respond to my request for an exchange. eBay vendors don't like it when they get neutral or negative reviews.Mean time, good luck with the machine and the replacement faceplate.
A VFD conversion is planned for this lathe. It will address the risks of snap-reversing (technically, "plugging" the motor), as well as the need to fiddle with V-belts to change spindle speeds.liveaboard wrote:Since I went to a VFD, the chuck pretty much stays put when reversing; the vfd slows down and reverses much more gently than a paleolithic motor.
