I have had a secondhand Jet 13x40 lathe for years. It was crashed before I purchased it, requiring me to do some repair to the carriage gear box and a new compound. However what I just repaired was solely my own doing. Disclaimer - I do not know what I am doing- this is just a hobby for me.
Making use of COVID-19 time at home I decided to clean up the lathe and go through it a bit.
Turns out that crash had moved the head gearbox / spindle on the bed (It bolts to the bed) I have had suspicions of this ever since I have had it. With a ground piece of 3/4” stock in the chuck protruding 1’ and a dial indicator on the carriage I took 4 measurements on the far left and right side, and turned the chuck 180 degrees to null out concentric error. Turned out the spindle was not parallel with the bed, and was off by about .006” per foot. 4 bolts and lots of fussing netted me an error less than .0005” per foot.
Now that I had moved the head it was time to get the tailstock aligned.
Out came the 5mm Allen key socket and 3/8” ratchet. With a little too much force I blew out the cast iron base where the adjusting set screws make contact on a tapered face of the tailstock base. I was trying to adjust it with the tailstock clamped firmly to the bed which was a no-no.
I made a new one out of some O1 steel I got from a buddy. All held in place with 5/16” hardware, and an 1/8” deep “key”.
So- lesson learned - be gentle.
Jet 13x40 tailstock repair.
Shop toys...
Jet 13x40 lathe.
Powermatic 1150 drill press.
I love Craigslist!
Jet 13x40 lathe.
I love Craigslist!
Re: Jet 13x40 tailstock repair.
What John said ! It may be a repair but that looks like it was well thought out and uses better and more durable materials than the factory OEM part was.
Nice job, on the repair!
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
nice work. If it ever has more issues. I have a 2nd Jet GH1340R complete tail stock.
-Dave
I live my life in a confused haze only to be interrupted by moments of Brilliance!
~Dave (me)
2004
~Dave (me)
2004
