It was the statement above that caught my attention.The plates need to be drilled and spaced for that ratio
If you understand what's required, that's all that's important.
It was that statement that caught my attention too.mklotz wrote:It was the statement above that caught my attention.The plates need to be drilled and spaced for that ratio
Troyke is still in business here in Cincinnati, so they might be helpful, too.pete wrote:Funny enough, I have a Ebay search on for Troyke rotary tables, this morning I just noticed that some at least were, and maybe all of them are 120-1 ratio. Since there were a lot of tables made by Troyke, then maybe a bit of luck would get you a set of dividing plates from one of those? And Troyke was a very respected name for producing very high quality equipment.
chucketn wrote:Marv,
The scientific calculator in Windows 7 does not have that function.
Chuck
I guess it depends on what you consider "complicated." I thinkmklotz wrote:We're making this too complicated. This is why they taught you fractions in the sixth grade.
That is what I more or less said in my first post on the first pagemklotz wrote:For example 25 divisions (N=25) on a 40:1 table (G=40)
T = 40/25 = 1 & 15/25 = 1 & 3/5
We need to turn the crank one full turn plus another 3/5 of a turn. To turn 3/5 turn we need a hole circle where we can count off fifths of a turn. That means a circle of five holes or any integer multiple of five holes (i.e., 10,15,20,25,30... holes).
For a 120:1 table we have:
T = 120/25 = 4 & 20/25 = 4 & 4/5
It should be obvious that, if N is a prime, the denominator will end up a prime number and you'll need a hole circle with that prime number of holes. Let's look at N=17 holes...
T = 40/17 = 2 & 6/17
T = 120/17 = 7 & 1/17
There's no way to reduce that (prime) 17 in the denominator so you're going to need a 17 hole plate.
All those lengthy tables in MH and elsewhere are completely unnecessary if you can reduce a fraction. Hey, it ain't nuclear physics. If it's beyond your math abilities, most inexpensive (<$10) scientific calculators have a key (often marked 'ab/c') to do it for you.
Hi Pete,pete wrote:Funny enough, I have a Ebay search on for Troyke rotary tables, this morning I just noticed that some at least were, and maybe all of them are 120-1 ratio. Since there were a lot of tables made by Troyke, then maybe a bit of luck would get you a set of dividing plates from one of those? And Troyke was a very respected name for producing very high quality equipment.
