Hope someone here has done this. I want to remove the badly damaged chrome off from a shower mixer and have the natural brass look.
I tried this using electrolysis but it damaged and pitted the brass pity bad.
Also I see that some commercially sold shower mixers have a brushed brass look which looks like brass but has brush strokes of darker brass in it which looks quite nice and then has what looks like a clear coat on it. Do you get a clear powder coat paint as it seems much more durable than 2k clearcoat.
stripping chrome.
Re: stripping chrome.
it's tough -> since anything that attacks the chrome is going to ding the brass also.
HCL is the only way of which I am aware to remove it
natural brass...well...it's eventually a polishing nightmare.
Sodium hydroxide and hydrochloric acid will each remove chrome, but each of them also have a strong appetite for zinc, which is a part of brass. When you subject the pieces to either of them you can expect the surface to be leached free of zinc, leaving behind a honeycomb of copper which has little strength and is porous. For those reasons, you'd be best served to remove the chrome mechanically---perhaps with a buffing wheel. The parts should lend themselves fairly well to that process, as they have to be buffed to be plated.
