I've done a trial setup using a stub arbor in the vertical spindle, to see if there is clearance and access (to get the cutter to the work), considering the size of the gear blank, and there is so I'll use a stub arbor although the spindle RPM isn't ideal, too high IMHO. My stub arbor is also 1", but considering the time and expense of going around altering (or making) new arbors, or altering cutters. I lso found I have other 22mm saws and cutters, so all things considered the $35 or so for an import 22mm arbor is worth the savings in time and Workshop Esperanto.
BTW, the dummy disk in the trial setup is P/lam-surfaced plywood, to test my tooth calculations (86) and appearance, and also my ability to hit the right number of index holes 86 times!
Enlarging Involute Cutter IDs
Re: Enlarging Involute Cutter IDs
Just because you hit the right holes once does not necessarily mean you will get it correct the next time...
I'd also be concerned about the wear of the cutting edge of the tool. Wood tends to be somewhat abrasive, so the keen edge will be lost after taking so many passes. As Bill alluded, making a setup piece doesn't necessarily guarantee that error won't occur when the desired part is made. If you feel you must become familiar with indexing, try just making dry runs instead of actually using the cutter. Alternately, a blank made of aluminum instead of wood would be better as well. Aluminum isn't abrasive.
The surface speed of the cutter to which you alluded may be more of an issue ----- depending on the resulting surface speed and the alloy of choice for the blank. Aluminum is very forgiving of overspeed, while stainless is not. Hardened steel is less forgiving than leaded steel. Needless to say, keeping the cut wet with oil will help.
Been there, done that, have the ugly part to prove it
And if you can position your successful test piece in front of the real thing, you will soon tell if your indexing is correct. If the cutter tries to take a bite out of the test piece instead of passing through the tooth space, something is awry.
