The other day I wanted to turn some little thumbscrews as shown in the drawing. I ground a little bullnose-looking form tool to make the neck. It worked fine for that cosmetic feature, but it made me wonder how you'd grind a similar tool if getting the shape exactly exactly right was more important. Any hints? Is it simply a matter of going slow and being careful?
-- Russell Mac
Tool Grinding Question
Re: Tool Grinding Question
There are form dressers available for those who have need, but they're pricey.
A comparator helps when grinding to close tolerances, as does good vision. With care, a form can be ground within a thou or two by hand. I generally use my Starrett radius gauges for the task and have been known to make a custom radius with a divider, scratching through thin brass shim stock. Any port in a storm.
I know it's not practical advice but I've been having great success with my fiber laser. I mark the top of the blank and grind up to it, then final dress it. You could try doing something similar with layout dye and a scriber.
So no real magic, I guess. Thanks, guys.
-- Russell Mac
-- Russell Mac
In your case a .150 drill blank / hard pin. Mount it @ 10-12 degrees rake in a square blank. Did this many times and it will cut.
- Attachments
- images.jpeg (6.6 KiB) Viewed 3116 times
This is more for completeness than in any way disagreeing with you, but if you mount it like that, you are no longer turning a circular arc, but an elliptical one.
With a nearby CAD, you could overlay the two and see what the actual difference is, no doubt extremely small.
You are correct, but for knob good enough. Being old school hand grinder it would be HSS + 5 minutes on a bench grinder. Becoming a lost Art with insert tools. Just giving the OP something to ponder, if not comfortable with hand or ? Grinding.arborist wrote: ↑Mon Oct 03, 2022 7:20 amThis is more for completeness than in any way disagreeing with you, but if you mount it like that, you are no longer turning a circular arc, but an elliptical one.
Hey...you are the first to quote me on this site.
Congrats , new to this forum !!
