Cut Off Toll Holder Hardware Source?
mcman56
Post by mcman56 »
I have an old very basic cut off tool holder and managed to break the wedge type clamping component. (I never realized it was such a poor design.) I don't remember where I got it but it came with a Made in India blade. It probably has little value but I would like to repair if possible. I don't even know what to call the hardware piece. It is sort of a wedge on the end of a threaded rod but made as one piece. See pictures. Can these be purchased anywhere?
whateg0
Re: Cut Off Toll Holder Hardware Source?
Post by whateg0 »
I'm not sure I've ever seen anybody selling parts to one of those holders. IMHO, if it's a poor design, and you have the machinery to make a new, better one, why not do so?
Post by NP317 »
Same thoughts here.
I don't know of parts venders for those items, but a machine shop provides the solution.
whateg0
Post by whateg0 »
I'm having trouble picturing how those pieces fit together. Clearly the screw goes through the bigger piece. I can't imagine the location of the smaller piece, or why the screw looks like it does. Without the rest, it looks like the screw was cut almost in half and then the remaining half broke.
What does your tool holder look like? Mine is similar to this.
The aloris looks a little different, as do some others, so they aren't all the same.
Edit: just figured out, you have one like this:
That ought to be even easier. If you aren't able to make one, send me the parts and I'll toss one together for you. I would be tempted to start with a grade 8 bolt. Machine the head to be the wedge part, then either make a new square nut, or use a heavy hex nut.
tornitore45
Post by tornitore45 »
I made the wedge part because thin blades would not clamp sqaure. The new wedge has a step forming a groove with the other plane of the holder.
Take 1/2 an hour to make once you find the smallest piece of metal to use.
mcman56
Post by mcman56 »
"I made the wedge part because thin blades would not clamp sqaure. The new wedge has a step forming a groove with the other plane of the holder.
Take 1/2 an hour to make once you find the smallest piece of metal to use."
I don't understand this statement but never thought of making one from an existing bolt. The shape is similar to a 82 degree CS screw. The odd thing is that the threaded part is 0.350 diameter and looks sort of like an acme screw. A 3/8 CS screw may work.
whateg0
Post by whateg0 »
It's hard to tell from the picture but it looks more acute than 82. The thread could be acme but again it's hard to tell if it's that or just a poorly formed or worn 60 degree thread. No matter really. If you make a new nut for it, it can be whatever you can make or source.
I'm curious what the female taper looks like. Surely they are not just both conical, but I guess as long as the male never gets drawn in far enough to seat in the female, it probably works ok.
mcman56
Post by mcman56 »
The female taper has some shiny spots so it looks like it gets contact.
choprboy
Post by choprboy »
The "threaded rod with wedge head" that broke looks like a standard flat head screw, with half the head ground off. Could you just find an appropriate screw and take an angle grinder to the head to match the original?
mcman56
Post by mcman56 »
The angle was different than a standard flat head screw. However, the idea of using a standard hex head bolt worked great. I only had a grade 5 but it seems adequate. Thanks for the idea.
https://ibb.co/wYGvspR
https://ibb.co/pfbf0r6
https://ibb.co/bWnnJh9
