Cutting Narrow Snap Ring Groove?
I need to cut an external snap ring groove on a 1/4" 303 SS shaft. McMaster Carr web site calls for the groove to be just 0.010 deep and 0.029" wide. I will only need to make one so would like to avoid buying a custom tool. At 0.010 deep any radius would seem bad. I have a few Ideas how to do this but am not particularity fond of any. Are there any recommendations?
1. It would seem pretty difficult to grind down a cutoff tool that narrow by hand. Are there any techniques or advice that can help? Is this the best option?
2. Looking on line, some people use a hack saw blade. I have one that measures 0.029" so that is close but how do you hold it? Would that leave a radius?
3. I have a 1 1/2" diameter HSS saw blade 0.032" wide but I don't know how I would hold that either.
4. The narrowest thing I have is a coping saw blade at 0.024". The package says something about heat treated but I have no idea if that would be hard enough or how I would hold it.
Thanks,
Dan
Thanks,
Dan
Re: Cutting Narrow Snap Ring Groove?
I have done it in all of the ways you are considering.
The saw generally works but you need to keep it spinning unless you can positively locate one tooth relative to the centerline of your shaft.
Generally speaking, there is often no way around grinding a tool unless you want it $ one. PH Horn sells most everything imaginable..but hang on to $
Would you recommend one over the others?
I have always carefully ground a HSS tool to the required thickness or less, - with proper side relief. A second offset cut can always be made to achieve the specified slot thickness, if required.
Yes it takes time to carefully grind the tool, but then the turning job goes quickly.
And I now have a small box with different width slotting tools for future use.
What RussN said.
Until one is capable of hand grinding lathe tools in HSS, he/she will be held captive.
Thin grooving tools are not that hard to grind, not even to proper size. Takes a little practice.
One thing that is VERY helpful is to lose the grinding rest. All it does is get in the way.
- liveaboard
I ground a hss cutoff tool down for making thin grooves.
I also made several from carbide, using an old saw blade.
I made internal ones using the sawblade teeth too.
All of these worked very well, and I've set many snaprings internal and external.
i grind my own cutting bits...it is a pain, but most of them have been in use on and off for 40+ years....
Live Aboard's suggestion works, but tough to do on very thin tools since they overheat so quickly when hit with the torch.
Someone once told me:
You can spend 30 minutes grinding a tool and 5 minutes doing the cut,
or you can spend 5 minutes grinding the tool and 30 minutes making the cut.
Your choice.
Thanks for this advice. I went ahead and tried grinding the end of a cut off tool to size and it was far easier than I expected. On this same subject, are the sides of narrow grinding wheels rated for side grinding? My grinder is a very basic 6" grinder with thin wheel. I'm wondering if I should upgrade to a wheel rated for side grinding. I guess I would then need a tool rest for the side.
- tornitore45
Sharpening a 10" 80 tooth carbide saw blade is not worth the time but cutting out one tooth like Liveboard did show is a great idea.
I have done the same thing and then sharpened that one edge with a diamond stone.
I don't know about that. There are cheap 10" blades out there, but if I am paying more than $50 for a blade, I can see the value in getting a little more life out of it. Now, if I didn't have the ability to sharpen it and had to pay to have it sharpened, any value in resharpening is probably lost.
We used to have a guy that would sharpen a 60-tooth carbide saw blade for $11.tornitore45 wrote: ↑Thu Jul 07, 2022 12:02 pm Sharpening a 10" 80 tooth carbide saw blade is not worth the time ...
Sadly, he is gone and his shop probably got scrapped as there was nobody interested in taking over a fully operational home business with more customers than you could shake a stick at.
