I have operated my lathe without coolant for years, as it makes little sense when not in production use. Coolant, allowed to sit idle, will generally start stinking quite quickly as the bugs that make it stink thrive in an anaerobic environment, especially when there's ample oil present, as there is with lathes. Thus, I no longer have the often needed cooling. I have turned to the use of ice when I need to control temperature of a turned object. An absorbent item (even news paper) placed on the ways, and a couple small ice cubes pressed to the heated surface reduces temperature rapidly. Very handy when one isn't afforded the luxury of allowing slow cooling.
Temperature a factor?
Re: Temperature a factor?
Those cool mist things seem to work ok. I bought a cheap one off ebay.
You really want to think hard about using those misters if you do not have positive ventilation away from you.
What Bill said. I used to run one regularly, but my entire shop was slowly becoming a black sticky mess. I have no clue what it was doing to my lungs.
Well, I'm too cheap to buy coolant anyway, so I could drink the mist if I got too heated myself. Since I don't use my shop every day, or even every week, I got a hot shot sprayer with ATF and kero to keep the machines from rusting.
I started working at TRW in 1995. While in a jig bore room @ 90° f , I had to put a set of holes in a Aluminium frame 12x14. Was True Position .003 S.
Asked for a temp gage and the manager wanted to fire me !! Had no idea about TCE on metal. One ol boy calmed him down and said I was right. Kept that job for 25 years. On large parts it can be a very big deal !!
