I searched “design book” here and went through the first few pages of results. Most things came back for steam topics.
I’m looking for something like a Handbook but with generic design principals. I’m constantly building odd mechanical things for people and spend forever researching things. The biggest time waster though is that I don’t always know what I’m looking for.
For example: I just roughly quoted a job that will require something like a big thrust bearing. A normal thrust bearing is too small and a slewing bearing for an excavator is beyond overkill. I know what it needs to do and I know how it needs to work, but I don’t know how to find or build something that may fall in between and do what I need it to. A bearing book is loaded full of great calculations and applications but in a weird scenario like mine, I need to figure out what I may be looking for first. Maybe I’d be better off making some delrin plates that could slide against each other? I have no idea. But if I were to go that route, what are some pitfalls or design considerations to plan for?
It’s not just the bearing example I’m looking for either. Just general machine design info. Books on tolerances, gears calculations, welding symbols, linkages and material strengths are great, but for farther along in the design process. I’m trying to find generic info for initial design principals.
Anyone ever seen anything like that or am I asking for a unicorn?
Griz
Design book recommendations?
Re: Design book recommendations?
Do you want the library list or just the first entries?
Machinery's Handbook
Mechanical Engineer's Handbook by Marks
Manual of Steel Construction
Design of welded Structures
Elements of Machine Design
Mechanics of Machinery
Formulas for Stress and Strain by Rourk
Engineering Mechanics
Engineering Design
etc.
It took some of us 4-5 years and a LOT of study time to collect all the books.
--earlgo
Engineering Design
etc.
--earlgo
The Engineer's Handbook by Marks looks like the closest place to start. From the descriptions I read, it sounds like they give sources throughout the book to get more specific about a topic. Maybe those will at least point me towards the right rabbit holes to go down.
I suppose what I was asking for probably doesn't actually exist. That would be too easy. In the mean time you'll all just have to put up with the little kid in me who never outgrew asking ridiculous hypotheticals and "but why?" every 5 minutes
Thanks for the lead earlgo
Griz
Griz
I have my father's Marks from when he graduated Purdue in 1933 and a newer copy that he gave me as a graduation present in 1974.
Both are very tattered and worn but worth their weight in gold.
To gain the knowledge you seek you need to read, read, read, and talk to knowledgeable people.
For reading I'd suggest back issues of Machine Design magazine, the Home Shop Machinist, and Model Engineer's Work Shop. You Tube is not bad for getting ideas, either.
Knowledgeable people may be difficult in this day and age.
Joining a model engineering club may be the answer here. I certainly found my memberships in 3 such clubs productive and worthwhile.
Thanks for the suggestions
Shigley’s Mechanical Engineering Design is one of the bible’s of the profession.
