Angle Plate - Step Block Maker?
Re: Angle Plate - Step Block Maker?
Post by SteveM »
The other method for pulling the lettering off would be what is commonly called "grave rubbing".
You put a piece of paper on top and rub with the side of a pencil and it marks the high spots but not the lows. You then get a negative image, like the Shroud of Turin.
Looks like it's in good condition, but take Rich's comments to heart and check it.
ctwo
Post by ctwo »
Let me think on that. Maybe not the best choice but I may have considered this block to be my reference. I've tried making a cylinder square and compare with a few other squares. It seems like I'm in the few thousandths of noise not knowing which one is correct, and I'm sure I don't make perfect measurements. Now watch, I'll be looking at a granite square reference.
see
https://www.ebay.com/itm/283879183252?e ... SwGYJevp5a
A cylindrical square made on a lathe is extremely accurate, assuming you turn it straight. If it is, and you've faced it properly, it has to be a true 90° angle when placed on the faced end.
ctwo
Post by ctwo »
I checked my cylinder square and note slightly less than 0.0002" deviation around the circumference. It's tight there and maybe my indicator is a bit floppy.
I determine a mid point and mark the top for a zero, then measure 4 points around and they are all 0. Then again and one is a tenth out. Then I'll bump the ball too hard and it's all out half a thou.
