My new (to me) lathe came on a homemade bench.
It's soaked with oil and probably a fire haxard.
Looking to make a new top out of 2x4 scraps turned on edge, like how they make bowling alleys. I will plane the top down to get it flat, if it isn't.
Then I figure I'll put something on top of that to have a smooth surface.
Masonite is the wrong choice, as Dr. Strangelove would say, "for reasons which are all too obvious".
What would make a good top material?
I can get thin (like 1/8") sheets of aluminum (in fact, that's what I'm going to use for a backsplash).
Or should I just cover it in plywood, give it a coat of something to seal it and call it a day, figuring it's going to take 20 more years to get this bad again?
Any other ideas?
It's pretty decent, but the top is made of three pieces of 2x12 with a sheet of masonite nailed to the top. One of the pieces of 2x12 (luckily the one in the back) is severely warped. lathe bench tabletop material
Re: lathe bench tabletop material
My idea of a good lathe bench top is 1/2" thick steel plate..but then everyone knows that I am a little strange.
I like my lathe benches to be solid stable and non warping..is the best way to keep the ways straight and level.
I have no way of cutting such a top, but I have a water-jet facility right up the street. Certainly worth asking.Bill Shields wrote: ↑Sat May 14, 2022 1:58 pm My idea of a good lathe bench top is 1/2" thick steel plate..but then everyone knows that I am a little strange.
Mine was cut the old fashioned way long before water jets were available...used an oxy acetylene torch.
Finished edges with a grinder
- Greg_Lewis
Here's mine. The design came from one of the magazines many years ago. While a little larger than what you need, the idea is that each end of the lathe is on a slightly higher perch so there is more room underneath for the inevitable bits and pieces you want to keep at hand. As Bill mentioned, the ends are on 1/2-inch plate but you may not need that for yours (Is that a 9-inch?). The whole thing is on an angle iron frame with leveling screws under each leg. The center is just a piece of 3/4 plywood as all it holds is the chip tray and tools.
