All of this is why there are scales that measure actual table position in addition to encoders on the motors/screws of the better CNC machines.
Lightweight machines with a bit of wear on the ways can benefit from a bit of drag from the locks...not the best practice but the world is what it is
Mill Gibs
Re: Mill Gibs
Re: Mill Gibs
I agree. Use the locks, or don't use the locks. Slight drag discourages self feeding. Doesn't work well if the slide has excessive wear, though.Bill Shields wrote: ↑Tue Feb 08, 2022 5:20 pm Lightweight machines with a bit of wear on the ways can benefit from a bit of drag from the locks...not the best practice but the world is what it is
Re: Mill Gibs
I have owned machines where I needed to follow the table with drag adjustments.
Built a very respectably running loco with it but it was a steep learning curve to get there.
Most annoying is that the machine was very new...
Re: Mill Gibs
I'm not the least bit surprised. That's often due to the fact that most machine tools are not hand scraped. That includes the exaggerated Bridgeport (I own one), which has ***no*** scraped slides. If they were, the average guy couldn't afford to buy them. The vast majority of such machines are either just milled, or ground.
Please, no arguments from those who think otherwise. Do not confuse flaking with scraping.
- seal killer
Re: Mill Gibs
Harold and Bill--
Prior to starting this thread, I figured the problem with my machine was probably the cross feed gib. I did that by putting some drag on the cross feed with the locks. By doing so, my indicated slop disappeared when moving the cross feed.
Of course, I learned that here, long ago.
--Bill
--Bill
You are what you write.
Re: Mill Gibs
Amazing what you can learn on the internet as long as you have the intelligence of a grapefruit to weed out the trash
- seal killer
