For reference, 2ml of oil:SteveM wrote: ↑Mon Dec 20, 2021 10:43 pm The guy on the wristwatch revival channel used a lube called Moebius 9010.
Found it on Amazon:
https://www.amazon.com/Moebius-Syntheti ... 003JIIN9U/
$39.99 for 2 ml.
Can't imagine how small the bottle is.
The gallon price?
$75,689
BTW, did you see the tapered reamer (broach) that he used to open a 0.21mm hole to 0.22?
That's a change of 0.0004"
My first watch hand made from thin wire wrapped around a small jewelers screwdriver, then twisted, soldered and painted. This one is easy as it just presses onto the center pivot.
Then my second watch hand roughed out. This one is more difficult as it is pressed onto the outer cylinder that is recessed below the dial. The minute hand will be more difficult. The second hand is original and presses onto the fully recessed center pivot. I made the flange with an awl, punching the hole into an appropriate sized hole to form. Then snipped out with scissors and filed a bit.
