rmac wrote: ↑Fri Dec 17, 2021 10:25 pm
I've never paid much attention to the nose radius when grinding my tools, so that's probably the first thing to correct,
Indeed! Nose radius coupled with feed rate spell the difference between rough and fine finishes.
For roughing, assuming you have the power and spindle speed to justify insert tooling, negative rake beats positive rake hands down. With a powerful enough machine, it also yields a respectable finish, although it may be coarse due to the heavy feed rate. The tearing that is so characteristic of mild steel and many of the steel alloys isn't a problem in those circumstances. However, once stock has been removed and it's down to finish cuts, positive rake tends to win the battle. For one, it lowers cutting pressure by a huge margin. Negative rake doesn't really cut at the tip (when it's applied properly). If it is cutting at the tip, depth of cut and feed rate are not appropriate. In either case, cutting resistance is extreme because the material is being plowed (pushed) off instead of being cut off. Positive rake doesn't do that.
So then, reduce feed rate and offer a reasonable radius, so the peaks of the cut are not as pronounced. The larger the radius and finer the feed, the lower the peaks. What's left, then, is to avoid tearing. Stainless steel usually cuts without tearing, much like free machining materials. Mild and medium carbon steel are notorious for tearing. I like to avoid them when possible and finish is important. If not, grinding is an acceptable alternative to establish a respectable finish, assuming the added operations and cost can be justified.
But back to cutting fluids ... what about brass and/or bronze? I never hear anybody talking about cutting fluids for them.
Many are best machined dry, but it's always a good idea to avoid anything with sulfur, which readily discolors many of the copper alloys.
If you like machining those alloys, there's one that's heads and shoulders better that almost all others. It's leaded phosphor bronze. Best machining material I've ever encountered. Machines perfectly well dry, but I'd likely suggest a lubricant suitable for aluminum if you must use some cutting fluid.
I don't have a lot of experience with the copper alloys, although I've experienced a large variety of them through the years. Just never a lot of the same one.
