Grub screws
Grub screws
Hi All, looking for an easy way to install a Lovejoy coupling on to a shaft with minimal tools , I am thinking of drilling a small hole into the shaft so that when I install a Grub screw into the coupling it would have a better grip.
Any thoughts?
Geo
Any thoughts?
Geo
Geo
Geo
Re: Grub screws
A keyway is a far better bet. If you have only light loads, might get away with your plan, but not recommended. You do not mention shaft size. For a small shafts, a through pin is acceptable, for larger shafts, definitely a keyway.
Re: Grub screws
Hi, shaft is probably 1/2” to 5/8” , not much load just an alternato
r, see pic.sorry I can’t seem to turn the pic around.If it ain’t broken keep working on it until it is .
Geo
Geo
- liveaboard
Re: Grub screws
That looks like a beefy alternator; 80A or more?
The torque is surprisingly high on that type of thing. I used to burn up V belts until I went to dual belts.
I I suspect a grub screw will fail.
A trick for people without the means to cut keyway grooves; Drill a hole along the shaft and hub, basically creating a round keyhole.
Tap it.
Then you can put your grub screw in, but the entire length with be on shear.
I usually drill a larger hole to countersink an Allen screw head. I use a drill smaller than the screw head, then cut the screw head down on the lathe for a snug fit.
For really high torque, I've used 4 screws.
This hub swings the boom of my hedgecutter, it's turned with a 10 ton hydraulic ram on a lever.
The screws are 14mm (9.16")
Tap it.
Re: Grub screws
liveaboard writes:
basically creating a round keyhole. Tap it. Then you can put your grub screw in, but the entire
This is referred to as a "Dutchman" for some obscure reason. I've used it successfully.
- liveaboard
Re: Grub screws
Funny;
I was taught it by a Dutchman.
Old cranky machinist had a shop across the canal from my place.
Re: Grub screws
14mm = 9.16"
We all know what you mean but this falls in with Harold's KG conversion.
Gotta love spell chuckers and inductive keyboards
Re: Grub screws
Commonly referred to as a Dutch Key.
I am from Dutch heritage but have no idea how the name came about.
Re: Grub screws
it's been called a "Dutchman" in machine shops for well over 100 years .
Maybe it comes from "Plugging the Dike ?
Rich
Rich
Re: Grub screws
80 Amps at 14 VDC is 1120 Watts is about 1.5 HP, substantial load for a set screw or grub screw with a sinosoidal load.
Re: Grub screws
There are keyless style couplings that are a better choice here than the keyed coupling you bought when you have no keyway…..
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
3/4" Hunslet 4-6-0
