What are they???
Rolland
What are they???
Post by Rolland »
Yes I know they are reamers but what are they made for. ??? They came out of a old guys gun shop. they are graduated sizes
I neglected to add sizes ..371, .3695, .343, .312, .250
Re: What are they???
Post by GlennW »
Could be for reaming pistol barrels to install liners. Fairly common for .22 cal.
Can't say that I have ever seen one, so just a wild guess.
earlgo
Post by earlgo »
You might consider writing to Brownells.com or to Midwayusa.com. They are gunsmith supply houses.
I've never seen anything like them either.
--earlgo
Rick
Post by Rick »
Never used one but believe they are called line bore reamers
Rick
pete
Post by pete »
What are the exact sizes and any manufacturer's name roll stamped on them? They should be marked with that up at the drive end and that might help a lot. I'd say Glenn's guess was probably accurate since at one time it was fairly common to reline barrels because of the rust caused by corrosive primer compounds. I don't think there for reaming revolver cylinders because of the very long pilot length they have. Brownells still show the drills and liners available, but no reamers I can find which doesn't mean much since they don't carry everything. Pacific Tool & Gauge would be one of the largest for barrel tooling and there bore reamers are quite a bit different design. But again that doesn't mean much.
atunguyd
Post by atunguyd »
You're overthinking it.
They were what the previous gun shop owner used to use to eat his Chinese takeout!
[emoji23][emoji23]
Sent from my SM-N975F using Tapatalk
