Toolbox drawer dividers
Just got a new toolbox top/bottom pair.
Several of the drawers have dividers welded into them. I would have preferred a totally open drawer, but the price was excellent, so I can't argue.
Not sure if I can get those dividers out, but I'd at least like to sub-divide the drawers more. There are some tool categories where I don't have enough tools to fill a 36" wide drawer.
I'm going to use some of those bamboo kitchen drawer dividers in the thinner drawers (1-1/2"), but for the deeper drawers (2-3/4", 3-3/4") I'll need a taller and probably stronger divider system.
Snap-on has some that I'd have to admit are nice, but I would end up spending more than I did on the box.
Anyone have something they are using that works well?
Seems the old one had been getting smaller for a number of years.Several of the drawers have dividers welded into them. I would have preferred a totally open drawer, but the price was excellent, so I can't argue.
Re: Toolbox drawer dividers
My box came with aluminum "T" stock cut to drawer length. There was double-sided sticky tape on the top (bottom) of the "T" so a person could stick it at any desired location in the drawer. All you would have to do is find some appropriately sized aluminum stock, cut it to length, and stick it into each drawer as you desire.
That could work for some of the shallower drawers. I don't see that as an option for the larger drawers as the cost will get pretty high.STRR wrote: ↑Wed Sep 29, 2021 5:52 pm My box came with aluminum "T" stock cut to drawer length. There was double-sided sticky tape on the top (bottom) of the "T" so a person could stick it at any desired location in the drawer. All you would have to do is find some appropriately sized aluminum stock, cut it to length, and stick it into each drawer as you desire.
Maybe double stick tape some angle on the sides of the drawer and stick / bolt a piece of flat sheet between those two points.
I have 3D printed some for my Kennedy boxes, but I don't know if that would work out for larger boxes.
Ted
Ted
Ingenious!Technical Ted wrote: ↑Thu Sep 30, 2021 6:50 am I have 3D printed some for my Kennedy boxes, but I don't know if that would work out for larger boxes.
Probably not practical for my use as some of the drawers are 31" wide by 19" depth and mostly 2" to 4" tall.
If you are going to put in permanent dividers -> you can always put in a piece of aluminum angle and pop rivet it to the drawer then cover with felt or whatnot.
Wood isn't out of the question either. https://www.youtube.com/watch?v=5jnyOWIPB1k
That's what I've been thinking all along. With a bunch of grooves cut into some 1/2" thick wooden strips as wide as the drawer is tall, you could more or less emulate the wildly adjustable setup that Snap-On has done with sheet metal. Or, if you know up front how you want to arrange your dividers, just cut the grooves you need and save yourself a lot of work.pete wrote: ↑Sun Oct 03, 2021 1:58 pm Wood isn't out of the question either. https://www.youtube.com/watch?v=5jnyOWIPB1k
-- Russell Mac
That's a n option, but not right now, as my table saw was one of the things I had to give away for the move.pete wrote: ↑Sun Oct 03, 2021 1:58 pm Wood isn't out of the question either. https://www.youtube.com/watch?v=5jnyOWIPB1k
If I remember, you should not use oak, as there is something corrosive in it (Gerstner toolboxes are poplar on the inside, oak on the outside).
Yeah it's the tannic acids within oak that create a rusting problem. Too bad really as oak is one of the stronger woods that's easy to find.
Depends on the box.
I've owned two different Gerstners. Neither of them were made of oak. First one was solid mahogany, which I didn't favor. Interestingly, it was purchased back in early '58 and cost only $75, new. The large one that accommodates a 24" rule. It was replaced with one made of solid walnut, which I still use today. Indications are that box costs about $1,800 today.
While shopping at Menards, saw those little bins that hang on a rack on the wall and thought I could use those.
I might have to take a drawer out and bring it to the store to size them up.Steve
